-   Encode, Convert for discs (https://www.digitalfaq.com/forum/video-conversion/)
-   -   VirtualDub settings, only outputs AVI file? (https://www.digitalfaq.com/forum/video-conversion/7039-virtualdub-settings-outputs.html)
Mejnour 02-17-2016 09:44 AM
Hello,
I extracted from a DVD a interlaced m2v file with PgcDemux and once I edited and saved AVI with Virtualdub I endend with a progressive AVI file.
Is that normal?
Goldwingfahrer 02-17-2016 10:14 AM
1 Attachment(s)
Is that normal?
yes
PGCDemux writes yet
video
Audio and SUBPIC in separate streams
Why You take VDub, you want "a" stream in AVI?
Do I cut the mpeg2 stream
I put video m2v + Audio AC3 [or mpeg1 Layer2] in Womble.
At the end there is a new mpeg2 stream .....without new encoding
Mejnour 02-17-2016 10:34 AM
I use this tutorial to correct audio and video from poor homemade quality DVD.
Thanks for the answer I will edit my video in premiere pro where I know I can keep the video interlaced.
Goldwingfahrer 02-17-2016 11:24 AM
1 Attachment(s)
AviDemux and VDub I put not one for editing mpeg. 2
mpeg2 cut with Womble or xilisoft video cutter 2 ... without re-encoding.
"Premiere Pro"
yes why not, as is but all re-encoded
I have Adobe CS6
When used to mpeg2 filter then must always be re-encoded.
The instructions in the link is incorrect.
VDub can output to AVI from mpeg2 streams
AviDemux 2.6.11 still can not encode MPEG2 by interlaced
