05-10-2024, 09:46 AM
1440 is good for easing the math but it doesn't go well with HD and UHD monitors, a downscale will follow eventually to 1080 or 2160 in hardware. And for VHS some like to crop the edges so the resolution is no longer 480, a little lower than that. Unfortunately it will never be an official screen resolution, After HD, everything doubles up.
05-17-2024, 12:58 PM
TCMullet TCMullet is offline
Originally Posted by latreche34 View Post
...It's about the resolution itself, 720 is a destructive middle man according to math, one loss from 480 to 720 and another loss from 720 to 1080 or 2160... Keep in mind resizing is a lossy process, anyone tells you it's lossless is misleading you.
Oh I'd never resize upward in more than one step. If I did 480 to 720, then wanted 1080, I'd go 480 to 1080. I've never heard anyone suggest resizing is lossless. EVERYTHING is lossy, unless explicitly stated otherwise.
capture, deinterlace, technical, upscale, vhs
Upscaling VHS before or after capture, which is best? BIGMEDIADINO Capture, Record, Transfer 3 10-23-2020 12:51 PM
Need help encoding DV to BD compliant 480i BFF Danfun64 Encode, Convert for discs 3 11-11-2019 08:21 PM
VHS upscaling to HD? waloshin Capture, Record, Transfer 5 06-10-2019 03:16 PM
Device to capture 480i in 720p? x77x Capture, Record, Transfer 13 07-23-2017 01:19 PM
Wanted to buy Blu-ray player for upscaling VHS Giana Capture, Record, Transfer 2 01-08-2013 11:59 PM
Thread Tools Search this Thread
Search this Thread:
Advanced Search
