How to convert DTS-HD MA 7.1 to WAVS (8 channels)?
Hi, does anybody here how to convert a DTS-HD MA 7.1 audio file into 8 WAVS (channels) files ? I tryed with eac3to and HD-DVD/Blu-Ray Stream Extractor as a GUI, but withtout success. All it does is only output 6 audio files instead of 8 (which is to total amount contained in a DTS-HD MA 7.1 audio file, if I'm not wrong).
Anyone can help me with this, please ? Thanks to answer |
Use the Google Luke, use the Google! :)
But seriously though, I am not too sure, I haven't tried it myself before. The issue when you work with HD audio is it gets really hard and technical. They made it so you cant screw with em even if you want to. Off the top of my head, Pro Tools could probably do it, but that's a big program. I don't have access to a Pro Tools machine right now or else I would attempt to take a look at it. -JMP |
