-   -   QTGMC 3.364 file? (https://www.digitalfaq.com/forum/video-restore/12428-qtgmc-364-file.html)
jtech1 01-17-2022 05:33 PM
QTGMC 3.364 file?
The QTGMC wiki page file download link seems to be broken. Anyone know where I can find the script, or can send me in private message? Thanks! I am setting up AVISynth+ and have no previous version of QTGMC.
jtech1 01-17-2022 07:03 PM
From going through GitHub, it looks like QTGMC.avsi file is gone and now there is STGMC.avsi.
https://github.com/realfinder/AVS-St...0up/STGMC.avsi
I am guessing it will work the same as QTGMC (comments in script says it is based on QTGMC 3.382. Anyone know the difference? I am using the latest version of AVSynth+ x64.
hodgey 01-17-2022 08:46 PM
The file links to QTGMC 3.382 in the description if one needs that version.
It seems the rename has something to do with STGMC being a maintainance version keeping compatibility with Avisynth 2.6, while there is an updated version of QTGMC here (in the MIX folder) with some claimed speed optimization and other improvements but will only work with avisynth+ and not with old avisynth 2.6.
jtech1 01-17-2022 09:20 PM
Thanks. I loaded that version and tried it... AVISynth+ x64. I get an error line 456, no function named SI_LogicalCores. The STGMC script works fine for me...
jtech1 01-18-2022 06:37 AM
I found SysInfo64.dll which got rid of the SI_LogicalCores issue... then on to missing EX_bs. Loaded EXTools.avsi but that did not solve the problem... I get no warnings with AVISynthInfo tool. If anyone has any advice on how to get QTGMC running, I'd appreciate it. Seems like new dependencies which have not been documented.
