| themaster1 |
10-14-2022 03:12 PM |
2 Attachment(s)
Try this:
LWLibavVideoSource("Clip.avi")
ConverttoRGB32(matrix="rec601",interlaced=false)
#### CCD COLOR DENOISING :
LoadVirtualDubPlugin("C:\Program Files (x86)\Virtualdub\plugins32\ccd_sse2.vdf", "CCD", 0)
CCD(8,1) #
converttoyv12(matrix="Rec601",interlaced=false)
spline36resize(last.height*2, last.width*2)
TurnLeft().DeStripe(1,0,256).TurnRight()
spline36resize(last.height/2, last.width/2)
DeStripe(1,0,256)
SpotLess(RadT=5,ThSAD=500000,ThSAD2=499000,pel=2,chroma=true,BlkSz=4,Olap=2,tm=false,glob=false,bBlur=0.0)
function DeStripe(Clip C, int "rad", int "offset", int "thr")
rad = Default(rad, 2)
offset = Default(offset, 0)
thr_ = Default(thr, 256)
Blurred = Rad == 1 ? C.Mt_Convolution(Horizontal=" 1 1 1 ", vertical = " 1 ", u=1, v=1) : C
Blurred = Rad == 2 ? offset == 0 ? C.Mt_Convolution(Horizontal=" 1 1 1 1 1 ", vertical = " 1 ", u=1, v=1) : C.Mt_Convolution(Horizontal=" 1 0 1 0 1 ", vertical = " 1 ", u=1, v=1) : Blurred
Blurred = Rad == 3 ? offset == 0 ? C.Mt_Convolution(Horizontal=" 1 1 1 1 1 1 1 ", vertical = " 1 ", u=1, v=1) : offset == 1 ? C.Mt_Convolution(Horizontal=" 1 1 0 1 0 1 1 ", vertical = " 1 ", u=1, v=1) : C.Mt_Convolution(Horizontal=" 1 0 0 1 0 0 1 ", vertical = " 1 ", u=1, v=1) : Blurred
Blurred = Rad == 4 ? offset == 0 ? C.Mt_Convolution(Horizontal=" 1 1 1 1 1 1 1 1 1 ", vertical = " 1 ", u=1, v=1) : offset == 1 ? C.Mt_Convolution(Horizontal=" 1 1 1 0 1 0 1 1 1 ", vertical = " 1 ", u=1, v=1) : offset == 2 ? C.Mt_Convolution(Horizontal=" 1 1 0 0 1 0 0 1 1 ", vertical = " 1 ", u=1, v=1) : C.Mt_Convolution(Horizontal=" 1 0 0 0 1 0 0 0 1 ", vertical = " 1 ", u=1, v=1) : Blurred
Blurred = Rad == 5 ? offset == 0 ? C.Mt_Convolution(Horizontal=" 1 1 1 1 1 1 1 1 1 1 1 ", vertical = " 1 ", u=1, v=1) : offset == 1 ? C.Mt_Convolution(Horizontal=" 1 1 1 1 0 1 0 1 1 1 1 ", vertical = " 1 ", u=1, v=1) : offset == 2 ? C.Mt_Convolution(Horizontal=" 1 1 1 0 0 1 0 0 1 1 1 ", vertical = " 1 ", u=1, v=1) : offset == 3 ? C.Mt_Convolution(Horizontal=" 1 1 0 0 0 1 0 0 0 1 1 ", vertical = " 1 ", u=1, v=1) : C.Mt_Convolution(Horizontal=" 1 0 0 0 0 1 0 0 0 0 1 ", vertical = " 1 ", u=1, v=1) : Blurred
Diff = Mt_Makediff(C, Blurred)
THR=string(thr_)
MedianDiff = Rad == 1 ? MT_Luts(Diff, Diff, mode="med", pixels = " 0 0 1 0 -1 0 " , expr = " X Y - X Y - X Y - abs 1 + * X Y - abs 1 + "+THR+" 1 >= "+THR+" 0.5 ^ "+THR+" ? + / - 128 +", u=1,v=1) : Diff
MedianDiff = Rad == 2 ? offset == 0 ? MT_Luts(Diff, Diff, mode="med", pixels = " 0 0 1 0 -1 0 2 0 -2 0 " , expr = " X Y - X Y - X Y - abs 1 + * X Y - abs 1 + "+THR+" 1 >= "+THR+" 0.5 ^ "+THR+" ? + / - 128 +", u=1,v=1) : MT_Luts(Diff, Diff, mode="med", pixels = " 0 0 2 0 -2 0 " , expr = " X Y - X Y - X Y - abs 1 + * X Y - abs 1 + "+THR+" 1 >= "+THR+" 0.5 ^ "+THR+" ? + / - 128 +", u=1,v=1) : MedianDiff
MedianDiff = Rad == 3 ? offset == 0 ? MT_Luts(Diff, Diff, mode="med", pixels = " 0 0 1 0 -1 0 2 0 -2 0 3 0 -3 0 " , expr = " X Y - X Y - X Y - abs 1 + * X Y - abs 1 + "+THR+" 1 >= "+THR+" 0.5 ^ "+THR+" ? + / - 128 +", u=1,v=1) : offset == 1 ? MT_Luts(Diff, Diff, mode="med", pixels = " 0 0 2 0 -2 0 3 0 -3 0 " , expr = " X Y - X Y - X Y - abs 1 + * X Y - abs 1 + "+THR+" 1 >= "+THR+" 0.5 ^ "+THR+" ? + / - 128 +", u=1,v=1) : MT_Luts(Diff, Diff, mode="med", pixels = " 0 0 3 0 -3 0 " , expr = " X Y - X Y - X Y - abs 1 + * X Y - abs 1 + "+THR+" 1 >= "+THR+" 0.5 ^ "+THR+" ? + / - 128 +", u=1,v=1) : MedianDiff
MedianDiff = Rad == 4 ? offset == 0 ? MT_Luts(Diff, Diff, mode="med", pixels = " 0 0 1 0 -1 0 2 0 -2 0 3 0 -3 0 4 0 -4 0 " , expr = " X Y - X Y - X Y - abs 1 + * X Y - abs 1 + "+THR+" 1 >= "+THR+" 0.5 ^ "+THR+" ? + / - 128 +", u=1,v=1) : offset == 1 ? MT_Luts(Diff, Diff, mode="med", pixels = " 0 0 2 0 -2 0 3 0 -3 0 4 0 -4 0 " , expr = " X Y - X Y - X Y - abs 1 + * X Y - abs 1 + "+THR+" 1 >= "+THR+" 0.5 ^ "+THR+" ? + / - 128 +", u=1,v=1) : offset == 2 ? MT_Luts(Diff, Diff, mode="med", pixels = " 0 0 3 0 -3 0 4 0 -4 0 " , expr = " X Y - X Y - X Y - abs 1 + * X Y - abs 1 + "+THR+" 1 >= "+THR+" 0.5 ^ "+THR+" ? + / - 128 +", u=1,v=1) : MT_Luts(Diff, Diff, mode="med", pixels = " 0 0 4 0 -4 0 " , expr = " X Y - X Y - X Y - abs 1 + * X Y - abs 1 + "+THR+" 1 >= "+THR+" 0.5 ^ "+THR+" ? + / - 128 +", u=1,v=1) : MedianDiff
MedianDiff = Rad == 5 ? offset == 0 ? MT_Luts(Diff, Diff, mode="med", pixels = " 0 0 1 0 -1 0 2 0 -2 0 3 0 -3 0 4 0 -4 0 5 0 -5 0 " , expr = " X Y - X Y - X Y - abs 1 + * X Y - abs 1 + "+THR+" 1 >= "+THR+" 0.5 ^ "+THR+" ? + / - 128 +", u=1,v=1) : offset == 1 ? MT_Luts(Diff, Diff, mode="med", pixels = " 0 0 2 0 -2 0 3 0 -3 0 4 0 -4 0 5 0 -5 0 " , expr = " X Y - X Y - X Y - abs 1 + * X Y - abs 1 + "+THR+" 1 >= "+THR+" 0.5 ^ "+THR+" ? + / - 128 +", u=1,v=1) : offset == 2 ? MT_Luts(Diff, Diff, mode="med", pixels = " 0 0 3 0 -3 0 4 0 -4 0 5 0 -5 0 " , expr = " X Y - X Y - X Y - abs 1 + * X Y - abs 1 + "+THR+" 1 >= "+THR+" 0.5 ^ "+THR+" ? + / - 128 +", u=1,v=1) : offset == 3 ? MT_Luts(Diff, Diff, mode="med", pixels = " 0 0 4 0 -4 0 5 0 -5 0 " , expr = " X Y - X Y - X Y - abs 1 + * X Y - abs 1 + "+THR+" 1 >= "+THR+" 0.5 ^ "+THR+" ? + / - 128 +", u=1,v=1) : MT_Luts(Diff, Diff, mode="med", pixels = " 0 0 5 0 -5 0 " , expr = " X Y - X Y - X Y - abs 1 + * X Y - abs 1 + "+THR+" 1 >= "+THR+" 0.5 ^ "+THR+" ? + / - 128 +", u=1,v=1) : MedianDiff
ReconstructedMedian = mt_makediff(Diff, MedianDiff)
Mt_AddDiff(Blurred, ReconstructedMedian)
Return(Mergechroma(Last, C, 1))
