Settings for Hybrid PAL/SECAM?
5 Attachment(s)
Hello! I have used some setting for deinterlace and denoise (while i still doesnt have a DMR) so i got some settings, they are good?
1 Attachment(s)
Video with those settings
DumbAndDumber - NTV (НТВ) Airing. Recorded on SP speed on MESECAM |
Is this the Dumb And Dumber movie? If it is so, then the original footage is progressive. It means you don't need to de-interlace your video.
If you do see interlacing in your video, then it means there is something wrong with your record and/or the way you capture it. |
And yep, this is a Dumb and Dumber, but broadcast from a Russian channel containing DVO (DoubleVoiceOver) Also i saw in the various broadcast of any films the sound getting Pitched to +0.5 which i will call afterwards PAL Pitched |
1 Attachment(s)
Dammit! I found out i was using an outdated version of Hybrid.
And i need to figure out how to speed my processing and evade asynch audio and sound, cuz in 2 hour 36 munutes i got this result. Dropped frames due to freak capture (Tape was seen a best days) Also i need help to convert from AVI to MP4 without asynch (cuz in this part could be some troubles cuz audio is PCM not AAC) |
Aaaaaand, I’m getting trouble, when AmaRec says it’s a dropped frame it still in sync but when I deinterlace, it getting out of sync.
The capture I’ll send later because its exceed the 100MB limit |
Why are you still deinterlacing it?
Therefore I think DMR could fix some issues, I’ll today or tomorrow send the capture of Ultranatural (REN-TV (Рен-ТВ) airing) where is asynch is VISIBLE! |
I did all by myself. I think this wall will closed. |
3 Attachment(s)
In WinRar archive: you will see Source record
The img is how many dropped frames i've got during THIS capture And the video is the from hybrid |
