-   Encode, Convert for streaming (https://www.digitalfaq.com/forum/video-web/)
-   -   Merged DV files variable frame rate? (https://www.digitalfaq.com/forum/video-web/14591-merged-dv-files.html)
Sodapop73 08-14-2024 04:10 AM
Hello,
I've got my PAL Digital8 tapes transferred via iMovie as QuickTime MOV format DV. I've then compressed the individual files with HandBrake, all resulting files are constant 50 FPS MP4. I want to merge all clips from one tape to one file, which I do with MKVToolNix. I use it, because it also automatically creates chapters that are named after the filename which are named after filming date. However, resulting MKV file reports as variable frame rate in MediaInfo. When I merge the clips using Avidemux, it's constant at 50 FPS. If I force 50 FPS in MKVToolNix "Default Duration/FPS" setting, the resulting file is constant at 50 FPS, but audio gets out of sync progressively. See MediaInfo attachments below.
Is the variable frame rate an issue? Does anyone have any clue why this happens?
INDIVIDUAL CLIP COMPRESSED USING HANDBRAKE
Format                                  : MPEG-4
Format profile                          : Base Media / Version 2
Codec ID                                : mp42 (mp42/iso2/avc1/mp41)
File size                                : 148 MiB
Duration                                : 1 min 39 s
Overall bit rate                        : 12.5 Mb/s
Frame rate                              : 50.000 FPS
Encoded date                            : 2024-08-13 08:13:02 UTC
Tagged date                              : 2024-08-13 08:13:02 UTC
Writing application                      : HandBrake 1.8.2 2024081000
Video
Format                                  : AVC
Format/Info                              : Advanced Video Codec
Format profile                          : High@L3.1
Format settings                          : CABAC / 5 Ref Frames
Format settings, CABAC                  : Yes
Format settings, Reference frames        : 5 frames
Codec ID                                : avc1
Codec ID/Info                            : Advanced Video Coding
Bit rate                                : 12.3 Mb/s
Width                                    : 720 pixels
Height                                  : 576 pixels
Display aspect ratio                    : 4:3
Frame rate mode                          : Constant
Color space                              : YUV
Chroma subsampling                      : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                      : 0.593
Stream size                              : 146 MiB (99%)
Writing library                          : x264 core 164 r3186 585e0199
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=500 / keyint_min=50 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=17500 / vbv_bufsize=17500 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Color range                              : Limited
Color primaries                          : BT.601 PAL
Transfer characteristics                : BT.709
Matrix coefficients                      : BT.601
Codec configuration box                  : avcC
Audio
Format                                  : AAC LC
Format/Info                              : Advanced Audio Codec Low Complexity
Codec ID                                : mp4a-40-2
Source duration                          : 1 min 39 s
Bit rate mode                            : Constant
Bit rate                                : 168 kb/s
Channel(s)                              : 2 channels
Channel layout                          : L R
Sampling rate                            : 32.0 kHz
Frame rate                              : 31.250 FPS (1024 SPF)
Compression mode                        : Lossy
Stream size                              : 2.00 MiB (1%)
Source stream size                      : 2.00 MiB (1%)
Title                                    : Stereo / Stereo
Default                                  : Yes
Alternate group                          : 1
MERGED MKV USING MKVTOOLNIX
Format                                  : Matroska
Format version                          : Version 4
File size                                : 4.04 GiB
Duration                                : 59 min 28 s
Overall bit rate                        : 9 726 kb/s
Frame rate                              : 49.934 FPS
Encoded date                            : 2024-08-13 17:28:43 UTC
Writing application                      : mkvmerge v86.0 ('Winter') 64-bit
Writing library                          : libebml v1.4.5 + libmatroska v1.7.1 / HandBrake 1.8.2 2024081000
Video
Format                                  : AVC
Codec ID                                : V_MPEG4/ISO/AVC
Bit rate                                : 9 553 kb/s
Width                                    : 720 pixels
Height                                  : 576 pixels
Frame rate mode                          : Variable
Original frame rate                      : 50.000 FPS
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                      : 0.461
Stream size                              : 3.97 GiB (98%)
Default                                  : Yes
Forced                                  : No
Audio
Format                                  : AAC LC
Codec ID                                : A_AAC-2
Bit rate                                : 170 kb/s
Delay relative to video                  : -66 ms
Stream size                              : 72.2 MiB (2%)
Default                                  : Yes
Forced                                  : No
Menu
00:00:00.066                            : 1999-07-21 07_56_35
00:00:06.658                            : 1999-07-21 08_29_23
00:00:59.458                            : 1999-07-21 17_49_56
00:02:39.426                            : 1999-07-21 17_52_23
00:04:17.762                            : 1999-07-21 19_07_12
00:05:33.794                            : 1999-07-22 17_43_37
00:07:45.762                            : 1999-07-24 15_20_28
00:10:03.810                            : 1999-07-24 15_23_49
00:11:03.170                            : 1999-07-24 15_27_36
00:12:19.650                            : 1999-07-24 15_29_16
00:13:49.634                            : 1999-07-24 15_34_24
00:14:14.466                            : 1999-07-24 15_35_05
00:14:24.034                            : 1999-07-24 16_15_43
00:16:23.650                            : 1999-07-24 16_18_12
00:17:42.146                            : 1999-07-24 16_43_28
00:19:01.186                            : 1999-07-24 17_09_31
00:19:46.434                            : 1999-07-24 17_49_19
00:21:55.298                            : 1999-07-25 07_22_46
00:22:51.842                            : 1999-07-25 08_09_16
00:23:10.658                            : 1999-07-25 08_11_12
00:23:33.858                            : 1999-07-25 08_12_18
00:23:46.946                            : 1999-07-25 08_12_37
00:26:20.226                            : 1999-07-25 08_16_08
00:26:23.202                            : 1999-07-25 09_15_56
00:32:59.202                            : 1999-07-25 13_27_37
00:35:10.466                            : 1999-07-28 07_27_53
00:35:33.474                            : 1999-07-28 07_28_30
00:36:23.234                            : 1999-07-28 07_29_47
00:37:04.674                            : 1999-07-28 07_50_09
00:37:58.242                            : 1999-07-28 07_51_12
00:38:33.506                            : 1999-07-28 07_52_02
00:39:19.554                            : 1999-07-28 07_54_07
00:39:38.242                            : 1999-07-28 07_54_37
00:40:58.690                            : 1999-07-28 07_56_20
00:41:13.122                            : 1999-07-28 07_56_50
00:41:57.634                            : 1999-07-28 07_58_26
00:42:17.634                            : 1999-07-28 07_58_57
00:42:30.690                            : 1999-07-28 07_59_34
00:43:26.818                            : 1999-07-28 08_02_24
00:44:30.146                            : 1999-07-28 08_03_35
00:45:03.522                            : 1999-07-29 11_56_54
00:46:51.842                            : 1999-07-29 12_18_12
00:47:44.162                            : 1999-07-29 12_48_48
00:50:08.194                            : 1999-07-29 12_52_46
00:50:10.530                            : 1999-07-30 05_02_50
00:52:36.706                            : 1999-07-30 14_01_59
00:53:36.962                            : 1999-07-30 16_37_44
00:55:15.874                            : 1999-08-01 12_12_28
00:58:32.962                            : 1999-08-03 11_32_20
MERGED FILE USING AVIDEMUX
Format                                  : Matroska
Duration                                : 59 min 23 s
Overall bit rate                        : 9 740 kb/s
Writing application                      : Lavf58.76.100
Writing library                          : Lavf58.76.100
ErrorDetectionType                      : Per level 1
Video
Format                                  : AVC
Width                                    : 720 pixels
Height                                  : 576 pixels
Color space                              : YUV
Bit depth                                : 8 bits
Default                                  : Yes
Forced                                  : No
Audio
Format                                  : AAC LC
Codec ID                                : A_AAC-2
Delay relative to video                  : 30 ms
Default                                  : Yes
Forced                                  : No
