-   Web Hosting (https://www.digitalfaq.com/forum/web-hosting/)
-   -   Plesk Linux default vhosts folder location, edit Plesk default page (https://www.digitalfaq.com/forum/web-hosting/3071-plesk-linux-default.html)
kpmedia 04-21-2011 11:52 PM
I'm always forgetting where it is. :o
/var/www/vhosts/%domains.com%/
Want to change or edit the Plesk default page?
Web Server's Default Page
This page is generated by Parallels Plesk Panel, the leading hosting automation software. You see this page because there is no Web site at this address.
You can do the following:
Create domains and set up Web hosting using Parallels Plesk Panel.
For more information please contact Administrator.
This is easy to do.
There are two files that matter:
  • /var/www/vhosts/default/htdocs/index.html
  • /var/www/vhosts/.skel/0/httpdocs/index.html
Also, if present:
  • /var/www/vhosts/default/httpsdocs/index.html
  • /var/www/vhosts/.skel/0/httpsdocs/index.html
Windows Plesk files are in similar locations -- C:\inetpub\vhosts\ instead of /var/www/vhosts
Leave only index.html and favicon.ico -- delete the other files. (Take a backup if you want, before deletion.)
Those files are for testing purposes, unnecessary to most users.
Create your own unique error page -- one that doesn't blab to the whole world what panel the server is running on!
Include links to projects, host ads, etc. Be creative. :thumb:
