-   Web Hosting (https://www.digitalfaq.com/forum/web-hosting/)
-   -   How to change your cPanel password? (https://www.digitalfaq.com/forum/web-hosting/5281-how-change-cpanel.html)
Brent 08-25-2013 08:29 PM
Now let's learn how to change our cPanel password
1) Click the Change Password icon
http://www.digitalfaq.com/forum/imag...cene02_1-8.png
2) First enter your current (or old) password
http://www.digitalfaq.com/forum/imag...cene04_1-7.png
3) Then enter and confirm a new password
http://www.digitalfaq.com/forum/imag...cene05_1-6.png
4) Then click Change your Password Now
http://www.digitalfaq.com/forum/imag...cene07_1-2.png
That's it! Your cPanel password has been changed. You'll now need to use this new password to login to cPanel, so be sure to keep it in a safe place.
http://www.digitalfaq.com/forum/imag...cene09_1-5.png
This is the end of the tutorial. You now know how to change your cPanel password
kumkum 08-13-2020 09:38 AM
Hi,
You have given detailed steps to change cpanel password in WHM and its awesome.
I don't want to arise any question about this and also don't want to disturb anything, but i want to share some details about changing cpanel password in SSH(putty).
If you are a server admin then you can change cpanel password with SSH access too and you can check the below steps:
1). First login to SSH as root.
2). You have to run the below given command to change cPanel password :
/scripts/chpass [cpanel-username] [password-you-want-to-change]
You might get this error :
warn [realchpass] Insecure passing of password on ARGV.
ERROR: /usr/local/cpanel/scripts/realchpass
interface. You can force a password
change through this script by setting
the environment variable
‘ALLOW_PASSWORD_CHANGE=1’.
if you get this error, then run this command and follow the procedure again.
export ALLOW_PASSWORD_CHANGE=1
