-   Web Hosting (https://www.digitalfaq.com/forum/web-hosting/)
-   -   Which EU VPS is better to sign up with? (https://www.digitalfaq.com/forum/web-hosting/8233-eu-vps-better.html)
Stendal 09-28-2017 10:47 AM
Which EU VPS is better to sign up with comparing deals from QHoster.com and Hosting.co.uk?
What's your advice?
rochelle 11-21-2017 02:26 AM
What's your advice?
Check out the websites of the host and get started by contacting thesupport team of the hosts. Else you can check out godaddy, scopehosts, vps9 networks and hostpappy for ssd vps.
kpmedia 02-07-2018 01:48 AM
As far as quality VPS companies, based in Europe -- and fully European, not just USA/etc companies with server locations in Europe -- then I highly recommend:
- EuroVPS (Netherlands)
- CherryServers (Lithuania)
- Jolt.co.uk (UK)
We've used each of them for many years now.
To address other hosts mentioned here:
What's your advice?
- Qhoster = scammy/scummy operation that is best avoided. Lots of valid complaints on other forums and blogs.
- Hosting.co.uk = no opinion at this time; nothing negative to say.
- Godaddy = great for shared ... VPS, eh ... needs improvement still. Great servers, support not so much.
- Scopehosts = another scammy/scummy provider, many complaints online, avoid
- VPS9 = unknown Indian host, no feedback, not suggested
- Hostpappy = unknown Indian host, no feedback, not suggested
^ Note that this post was banned for spamming those 3 hosts. So for that reason alone, none are suggested.
Need a good web host? — Read our 2018 Review of the Best Web Hosts
Quite often, problems with web sites are caused by having a rotten web host. Worse yet, many hosts try to blame you (the customer) for the problems! So dump that lousy company. Say goodbye to slow sites, unresponsive support techs, and downtime. Find yourself a new host today. Whether you need shared, reseller, VPS, semi-dedicated, cloud, or dedicated hosting, something on our list should be a good upgrade for you.
