problem creating dvd from download mp4
hi...
i downloaded all 15 chapters of a serial cliffhanger in mp4 format... a menu is nice...but not as important as playing this movie. i tried avs, nero, windows, etc. and nothing works. i already threw away one dvd-r...but this is simple learning curve do i need to convert these mp4 files into something else...if so...what and how? what software do i need to actually WATCH this on my sony dvd player thanks.... a confused newbie |
some additional information to the above
hi... i downloaded all 15 chapters of a serial cliffhanger in mp4 format...
a menu is nice...but not as important as playing this movie. i tried avs, nero, windows, etc. and nothing works. i cannot even load these mp4 chapters into the various and nefarious dvd burning program....also....each dvd-r has plenty of room to do the whole project....but each program says i have too much data. others have 15 chapters on one dvd-r .... it appears i need three dvd-r to do this....obviously something is wrong as the total data is only a little over 1gb and the dvd-r has 4.7gb i already threw away one dvd-r...but this is simple learning curve do i need to convert these mp4 files into something else...if so...what and how? what software do i need to actually WATCH this on my sony dvd player thanks.... a confused newbie |
You need to convert them to mpeg2 than put them on a DVD. Not sure what kind of quality u are going to get from downloaded MP4 files. My guess, it is going to be junk...Sorry....
You only messed up 1 disk? If you do this a lot, 1 disk or 400 disks doesn't really matter.... |
The steps of creating a DVD are, in this scenario:
Creating menus has been discussed a number of times on this site, and on the DVD collector/entertainment site TVPreservation, at http://www.tvpreservation.com/forum/...o-tech-21.html Most all pain-free authoring programs are payware. You're actually in luck, as B&H has Ulead DVD Workshop 2 on sale for an amazing $49 -- and it's pro software, perfect for this task.
The MPEG-4 container is usually Xvid or H.264 video, which can be pretty decent if it was encoded properly. Being from archive.org (U.S. Library of Congress archives), it's probably pretty decent -- althought it would also depend on how many years ago the files were made. |
hi...software unavailability from newbie
hello....thanks for all the help so far.
at least for chapter 1....FORMAT : ISO Media, MPEG v4 system, version 1 if i can just get the darn things formatted correctly, i can forgo the niceties of menus. ==================== this is what i uncovered so far: ==================== corel ulead software B&H still has the corel ulead software listed but the software apparently no longer exists....i tried to find it on the internet. i put a note into their sales department but it came back in mailer demon. could not be delivered. ================ is there an alternative? ================ media convert (online) i tried using media convert....but it just hung up and died....so scratch this as an option. ================ imgburn i downloaded imgburn but cant try it as i still dont have the encoding/menu programs. ================ photoshop is this the program you so kindly suggested for menus? Adobe Photoshop Elements 8....supposedly this works on WINDOWS 7 this IS available at amazon for about $50 ============= i can get the burning and menu systems...but i am not certain about the encoding system...can you help....sorry to be such a nuisance...but i want to get this right, and your checklist is fantastic. thanks so much |
Gspot it. See the section called "How to analyze digital files" about 40% down this page: http://www.digitalfaq.com/guides/vid...nd-sources.htm Quote:
The software for menu-less discs will cost double the price of the better DVDWS2. Quote:
You don't need to search for it. Quote:
