ATI All In Wonder 4-pin internal audio cable?
Hello, i was reading your article on the internal audio cable. I cant seem to find a 4 pin to mini 4 pin that uses 4 wires, everything i find uses only 3 wires and i cant tell in the pic if that is what you are using. so is a 3 wire 4-pin to min 4-pin whats supposed to be used?
Your clarification is appreciated. Bill
It's a 4-pin cable, sometimes referred to as the CD audio cable.
Did you see this thread yet? http://www.digitalfaq.com/forum/vide...ti-wonder.html |
the plug is 4 pin, but only 3 wires is fine - they just share a ground
Great, Thank you.
I just needed that clarification on whether it had to be a 3-wire 4-pin or 4-wire 4-pin(i don't think a 4 wire exists) Thanks Again. |
Hello. I need help as far as what kind of cable this is. Yes I know, 4-pin (4 wires) to 4-pin (3 wires), but I don't know if there is more than one type of this variety. If anybody can help, here is my thread:
http://www.digitalfaq.com/forum/vide...html#post44817 Thank you. |
