Toshiba SD23VB has a TBC? Pattern effect using s-video?
Hi
I wonder if you could help me i read your VCR guide and need a little help. My video recorder is a Pal Toshiba SD23VB, can you tell me if this machine has TBC (and will i need it for what i'm going). and also is there a way (or hack) that i can get this VCR to ouput a Svideo signal in VCR Mode (its only doing it in DVD mode) I also have a pattern effect on my capture using RGB Svideo my orignal post is here if you can help in anyway - http://forum.videohelp.com/threads/3...o-Capture-Help thanks
If you need anything else, reply to this post (not via PM). Thanks. :thumb: If you're not already a member, register here: http://www.digitalFAQ.com/forum/register.php |
