Is description of 4:1:1 subsampling in guides correct?
From this site's Guide to Understanding Video Sources, Part 2 – Capturing Videotapes—
No. they are not correct, Here is a better description:
https://en.wikipedia.org/wiki/Chroma_subsampling Believe it or not 4:1:1 has twice the vertical chroma resolution of the 4:2:0 but half the horizontal chroma resolution of 4:2:0, But since more chroma resolution is needed horizontally than verticall 4:2:0 tend to look better than 4:1:1. |
What page was that on? It does need updates.
But the main point remains: 4:1:1 is one-fourth of color data, and half of the color data present on consumer analog formats like VHS. It throws away data when used for conversion. The Wikipedia definitions are wonky and confusing, and ultimately misleading. RED is better. |
1 Attachment(s)
Think of it like this: 4:H:V where H is the number of chroma samples in a 4 horizontal luma pixels on a given scan line, and V is the total number of vertical changes of chroma in the 8 total pixels (from line one to line 2 in all 4 pixels).
4:2:2 has the same vertical chroma resolution of 4:1:1 and the same horizontal chroma resolution of 4:2:0, it has the best of both worlds. 4:4:4 simply means for each luma pixel there is a corresponding chroma pixel assigned to it. Here is a better visualization of what I said: http://www.digitalfaq.com/forum/atta...1&d=1590565056 |
Latreche34, your explanation conflicts with the one I linked to at red.com. You are showing the output chroma as having the same hue as the first of the sampled input pixels. Unless I'm mistaken, the RED site is saying the output is an average hue across the sampled range.
In other words, for 4:1:1, on each row, a set of 4 input chroma pixels (say, two red followed by two blue) is sampled to produce one output pixel (a four-wide purple); the output gets the average hue of the four input pixels, not the hue of just the first input pixel. Which is correct? |
It's a convention there is nothing magic about it, They decided to gauge chroma that way as I explained it above, just like any other unit of measurement, for instance the foot, or the Mac for airplane speed. I haven't read your link but they must have gotten something wrong. The colors in the wiki picture are for presentations purposes, They have nothing to do with the chroma primary colors. That's where your confusion lies.
To answer your question about the sampled range, When the signal gets digitized I believe it takes the 4 pixels's average chroma value, It wouldn't be possible to measure a single pixel or 2 pixels otherwise it is considered 4:4:4 capable capture card which is not. But the sampling is time driven not pixel driven because the analog signal has no pixel structure it is just an infinite analog values up to the carrier frequency limit. For the digital signal and imaging sensors it is a different story, we are only concerned about video capturing. |
In progressive domain 4:2:0 chroma subsampling might be okay.
But IMHO, 4:2:0 in interlaced domain is equally bad as 4:1:1. This page explains 4:2:0 and interlacing quite well: http://www.mir.com/DMG/chroma.html That's why I long ago argued for motion-adaptive 4:2:0 to 4:2:2 conversion, when interlacing is present: http://rationalqm.us/autoyuy2/autoyuy2.html https://forum.doom9.org/showthread.php?t=97987&page=1 Simply speaking: interlaced 4:2:0 messes up your chroma more than 4:1:1. 4:1:1 - especially for VHS - is more than sufficient. VHS has 80 lines of chroma. 4:1:1 can offer 180 lines of chroma. So the Nyquist-Shannon limit is overly satisified. Upsampling 4:1:1 to 4:2:2 can easily done with some clever turnleft().nnedi3(dh=true).turnright() trickery. Anyways I only work in 4:2:2 with interlaced video. I convert to 4:2:0 *after* deinterlacing/upscaling. |
Indeed 4:2:0 is almost as bad as 4:1:1. I myself started to move away from 4:2:0. Usually after I encode and de-interlace I always downconvert to 4:2:0 but after doing few experiments on playback compatibility with files encoded at 4:2:2 I found out most devices play them back with no problems, and here is the kicker, the files are only about 15% bigger, So I don't see any reason for downconverting to 4:2:0 from now on.
I started a thread about this two weeks or so ago but no one seem to care I guess: http://www.digitalfaq.com/forum/vide...ing-422-a.html |
However, due note that is strictly for NTSC. PAL is less obvious. (PAL users always liked to poke fun at NTSC, with "never the same colour" jokes, but PAL is no better. I'd even go one further, and suggest anybody that took the saying seriously never worked extensively with both formats. Each has equal numbers of warts.) Quote:
2 Attachment(s)
What you mean is: Lot's of implementations are incorrect! Most chroma-upsamplers are doing it wrong by just - doing a nearest neighbor chroma-upsampling, or - doing wrong chroma placements and the like. But from a practical perspective even YUV8:1:1 is sufficient for VHS, if using the correct upsamplers. Have alook at my example image attached to this post. - The left column shows wrong chroma upscaling: nearest neighbor scaling. It shows horrible staristepping - The mid column shows linear upscaling: the stairstepping is highly reduced. - The right colums shows nnedi3 upscaling: the stairstepping is almost gone. just some blurring in the horizontal domain remains. Even 8:1:1 chroma using a decent upscaler (I used nnedi3) looks quite acceptable. Thus - again - the math is not wrong here. It is the implementations. In the past I recovered many NTSC DV-footage YUV411 to YUV422 using this approach. Noone was able to tell that it was not YUV422 in the first place! EDIT: I added a real-life example. |
I'm sure the math is correct. But the math isn't visual. What we see is most definitely a worse picture when capture as 4:1:1/DV. Again, cooked colors, lost color. So math be damned. Theory vs. practical application. What "should be" simply is not.
A reference on that page is http://www.adamwilt.com/pix-sampling.html which says The color sample is co-sited (located at the same place) as the first brightness sample in each 4-pixel group, and the color at that location is simply replicated over the following three pixels. Likewise, it is not hard to just Google and find more references that say each chroma sample is based on just the first pixel's color, e.g. http://www.jayandwanda.com/DigitalSampling.html which shows that a particular software DV codec seems to implement 4:1:1 in exactly that way! But then, like the RED site, there are others that say that no, subsampling has the effect of averaging the color across the pixels, e.g. http://www.dvxuser.com/articles/colorspace/ which also used a software codec to prove this point, and the notation reference https://poynton.ca/PDFs/Chroma_subsampling_notation.pdf agrees with this as well. So it seems to me that the mechanism of subsampling varies by implementation. I do not know what happens in my Sony DV camera, but I am guessing it is more likely to be averaging. Regardless, how would be best to address this in the guide I asked about? |
1 Attachment(s)
I agree, that the kind of sampling (nearest neighbor / average) is dependant on the implementation.
I think the best would be, to mention both kinds of sampling in the guide. http://www.adamwilt.com/pix-sampling.html shows correctly how sampling is done. But it also shows, how chroma is being upsampled incorrectly. http://www.jayandwanda.com/DigitalSampling.html Somehow these explanations simply feel wrong, because 4:1:1 and 4:2:2 simply do not have a vertical component. Anyways the whole concept, that a single chroma sample value in 4:1:1 / 4:2:0 strictly is copied over four luma samples is wrong. Sampling theory tells that you need filtering to upsample subsampled chroma. (Generally speaking this counts for ANY kind of continuous signal) If done correctly the losses aren't apperant as the linked guides might suggest: http://www.digitalfaq.com/forum/atta...1&d=1590736410 |
And your above images are mostly about resizing, not the data loss from DV conversions. Quote:
DV throws out data from that 4:2:2(ish) consumer analog source, which now has noticeable damage, and is therefore bad. The end. DV has not just color compression, but blocks, and other noises. Technically 4:2:0 throws data out, but the loss is less perceived, therefore not terrible. Thus why it was chosen for DVD, BD, broadcast, and streaming specs. |
YUV4:2:0 has been chosen in the past, because analogue distribution over formats like PAL and SECAM had conceiled the vertical chroma issues due to their delay lines. Even most new-ish TVs do NOT properly upsample interlaced YUV4:2:0. I can see lot's of chroma interlacing or vertical chroma smearing artifacts, that could have been avoided using proper "algorithm guessing". |
Scaling is important. And quality of the scaler matters. And noting the limitations of scaling. |
