Fujinon BMD lenses Hirose 12 pinout?
Hi !
So I i'm working on finding the pinout of the Fujinon lens with a hirose female shell size 10 & 12 pins Lens type S16x6.7BMD-D29, so BMD series I want to confirm this or increase information level on this 1. Input - Zoom control 2. Input - Focus control 3. Output - Vref +4.50V 4. Output - 11.32V 5. Input - No idea what it's doing, another mode ? 6. Input - Iris mode, Local Manual / Camera Auto 7. Ground 0V 8. Input - Mode ?? 9. Input - Mode servo on focus 10. Input - Mode ?? 11. Output - Vref +2.25V 12. Ouput - Vref +6.67V So i'm able to control zooming by control of pin 1 connecting via a protection resistor like 10k to ground or +11.32V, zoom servo is also working putting via protection resistor +11.32V on pin 9, and a pot with wiper to focus control pin 2, pot min to 0V and max to +11.32V For now I don't really know what pin 5, 8 and 10 are doing, pin mode 8 seems to be the zoom speed, slow speed when put high via protection resistor to +11.32V Pin 3 vref +4.50V is maybe for some logic in certain types of remote ? Pin 11 vref ?? +2.25V maybe ''low side'' for the focus & iris pot Pin 12 vref ?? +6.67V maybe for ''high side'' for the focus & iris pot Since the pot is not full range when putting 0V and +11.32V on wiper min and max Thanks !! Lee |
Ok so final information,
First I have inverted the pinout on my first post..... now remote assembled final pinout is PINOUT FUJINON BMD 1. Input - Mode Servo Focus ON – 0V OFF / +12V ON 2. Input - Mode Servo Zoom ON – 0V OFF / +12V ON 3. Ground 0V 4. Input - Iris mode, Local Manual / Camera Auto – 0V Iris Local Manual / Float Auto 5. Input - Iris control – Pot wiper, pot between Vref +2.25 / +6.67V 6. Output - 11.32V – Supply from cam +12Vdc via fusible resistor 20 Ohms 7. Output - Vref +4.50V ?? Probably to supply some logic in some remotes 8. Input - Focus control – Pot wiper, pot between Vref +2.25 / +6.67V 9. Input - Zoom control – Pot wiper, pot between Vref +2.25 / +6.67V 10. Input - Mode ?? 11. Ouput - Vref +6.67V 12. Output - Vref +2.25V Since I don't really know what is going on in the the lens electronics, and I don't have the schematics.... I have put a 1k resistor in series with each inputs to limit current, just in case, Hope I could help someone, feel free to add information ! |
