Terrible tracking issues with my VCR?
I could use some advice, any suggestions are appreciated!
Hello! I have a JVC-HRD4050U, and im having playback issues specifically with all tapes. I keep on getting “no signal” but I am still able to hear audio, and sometimes the video will display but only very briefly before becoming very noisy or “snowy” then I will recieve no signal again, still hearing the audio. I have dumbed it down to solely being a playback issue as I am able to access the menu on the VCR without problems, ever. Pressing the tracking buttons will sometimes help for playback, but eventually the same thing happens within about 5 seconds before it losing tracking again. I also get no signal when I FFWD, RWD or Pause I have cleaned the tape heads, and also tried my hardest at realigning the tape path alignment as I thought this might have been the issue. I had no luck, and it didnt make a difference so I just set them back to where they were originally before I had moved them. Is there anything else I can try? I’ve also tried both Coax and the AV method of connecting, both resulted in the same outcome unfortunately. I have been trying to figure this out for hours now, hopefully ill be able to get it working properly. Thank you |
So you’re just hooking it up to the TV? You aren’t trying to capture? Are the tapes EP/SLP?
2 Attachment(s)
Assuming:
1 You cleaned the heads really well 2: You didn't remove grounding screws (bad grounding= snowy pictures) 3: Ribbon cables are well seated in their sockets for the AC head and Drum/preamp (check again please),all the way down It could be: 1- Tape tension issue (back tension arm) (check with your finger on the left side of the tape path if the tension if good (not loose),same thing on the right side 2- Can be an issue with the Post guides (P2,P3) that need a tweak 3- Check / adjust your AC head The AC head is a set of two heads: one for audio linear a.k.a mono (reading & recording) one for control track (tape speed infos reading SP/LP, and Sync pulses i believe) If not set properly it certainly can affect the quality of audio and also video to the point it's snowy and audio is muffled. Adjusting it will not be easy without a scope but it can be done good enough (i did it on my philips, and some other vcrs) two videos for you: Adjust the AC head: https://www.youtube.com/watch?v=fazLIPQqKLk back tension (~8min mark): https://www.youtube.com/watch?v=1dY0...Vuc2lvbiB0YXBl |
