Best lubricants for VCR/VTRs?
Has anyone had experience with GC Electronics or Permatex White Lithium Lubricant? I read about a bad experience with it.
Or what about Phonolube? Electrolube? Superlube? :question: Thank you for any advice. |
Hint:
Call one of the repair places we recommend here: http://www.digitalfaq.com/forum/vcr-...place-jvc.html FYI, I'm currently reworking that list, so details are still missing. |
What area are you wanting to lubricate? Panasonic uses molybdenum grease SPARINGLY on metal to plastic interface and white molycoat grease on plastic to plastic parts. The molycoat is part number RFKXEM30L, a Panasonic part number. It is non-spreading.
Thanks. The JVC I had started to make screeching sounds after removing a tape caught in the takeup side. I think it is plastic to metal, but would white lithium grease work in both scenarios? And are those Panasonic grease applicable to JVC? Typically I believe plastic parts are self-lubricating but I do not have any other explanation.
JOTS said they use lithium grease and phonolube, while Southern Advantage uses lithium grease as well. |
Well since I am in the US I was planning to buy Permatex's white lithium grease, as seen here:
http://www.amazon.com/Permatex-80345.../dp/B000HBNV58 Servisol seems to have a number of greases, such as Silicone Grease 70 and Super 10, but I do not know how any Servisol's product compares with Permatex. http://www.crcind.com/csp/web/functd...brand=SERVISOL |
