-   -   Starting capture with AG1980 and ATI 9600? (https://www.digitalfaq.com/forum/video-capture/10879-starting-capture-ag1980.html)
bobbintb 08-10-2020 11:08 AM
I got an AG1980 from tgrant and an ATI 9600, the one with the proprietary cables and such. I followed all the install instructions for the drivers and MMC (http://www.digitalfaq.com/forum/vide...der-hacks.html and http://www.digitalfaq.com/forum/vide...g-ati-mmc.html) and am now trying to capture. I got virtualdub with all the filters but when I start a new capture and select the ATI card I just get static on the preview when playing a tape. I connected to svideo from the AG1980 to the purple dongle. I must be missing something. I'm using XP sp2.
lordsmurf 08-11-2020 03:40 AM
Is VirtualDub input on s-video, not tuner? :hmm:
BW37 08-11-2020 02:36 PM
If you haven't read it yet the VirtualDub settings guide is invaluable.
BW
bobbintb 08-12-2020 11:42 AM
Thanks, that was it. It took a while to find the setting. Follow-up question. I downloaded the 1.9.11 pack from this site with all the plugins. I'm guessing VirtualDubMod is the exe I should run. Is that right? If I just use the VirtualDub.exe the screen goes black when trying to capture and I have to hard reboot my computer.
