Automatically drop frames during empty Hi8 tape?
Many years ago, I captured Hi8 with (I think) this ADVC device. Those captured were trash compared to the captures I get now, but one thing that was very helpful was that those captures don't contain any "empty tape", i.e. the blank frames in between scenes. I don't know how, but it appears that my setup back then didn't record, or dropped, the frames during these segments. With my current setup, there is a lot of blank screen. Is it somehow possible to have my setup drop these frames again? That would save a lot of time.
If not, what editing software is recommended for editing lossless AVI (Huffyuv) without reencoding to another codec? Does Adobe Premiere work, or LosslessCut? |
What you want is actually a bad thing. DV transfer loses footage at stop/start of recordings. It's just a few seconds, but those seconds can be important. Analog capture records every second.
Ah, that's good to know! There were indeed second missing, which is not what I want at all. Thanks :)
What do you use for lossless editing/trimming? |
trimming (remove stuff) = VirtualDub, using Direct Stream Copy mode
editing = Premiere Pro |
In this case, what is preserving all your frames is your AVT-8710 frame TBC. You likely weren't using that during your previous capture attempts. The AVT-8710 is giving your capture card a proper, stable signal no matter what is fed into it from your camera/VCR.
In between video segments you're seeing color bars, right? That's what the AVT-8710 generates when it has no usable input frames. |
