-   -   VirtualDub AV sync problem? (https://www.digitalfaq.com/forum/video-capture/12684-virtualdub-av-sync.html)
KhAoS182 04-04-2022 05:26 PM
Hello everyone!
I have started to make my first captures with VirtualDub using the HuffYUV codec, the quality and everything is fine, only that the audio desynchronizes from the video after a few minutes, If I change the timing settings it has happened that the audio slows down to adapt to the video.
I'm using Huffyuv 2.1.1 - CCESP Patch 0.2.2. I have tried a thousand combinations in this timing tab and none of them are satisfactory, I don't know if the problem can come from somewhere else.
This is my timing configuration: https://gyazo.com/02b7cdb91c16e1599be7c3e15895d879
This is my setup: JVC HR-S3900U > Panasonic DMR-ES15 > ATI TV Wonder HD 600 USB > Windows 7 64 Bits > VirtualDub 1.9.11
This is my computer:
Intel i7 4790K
G.Skill Ripjaws X DDR3 1866 PC3-14900 2x8GB
Gigabyte Z97X-UD5H-BK
Gigabyte GeForce GTX 970 WindForce 3X OC 4GB GDDR5
Samsung 850 EVO (OS)
Seagate 3TB HDD
Thanks to everyone!
lordsmurf 04-04-2022 06:03 PM
- What card?
- Attach images to the forum, do not hotlink.
KhAoS182 04-04-2022 06:11 PM
Sorry. You mean capture card? I have ATI 600 USB.
I’m thinking to buy this computer, what you think?
Intel Pentium 4 3.0GHz
AsRock 775i65G
Kingston 2x1GB DDR400
Maxtor 80GB (OS)
Seagate 2TB
msgohan 04-04-2022 06:54 PM
2 Attachment(s)
Here's the image from the link, properly attached. I hope my PC didn't catch anything from that site!
KhAoS182 settings:
Attachment 14997
My settings:
Attachment 14998
Seagate 3TB HDD
Does VDub report any dropped or inserted frames for these captures that desync?
thestarswitcher 04-04-2022 09:06 PM
As long as you have a TBC active in the chain, I have "Correct video timing..." off and leave it checked on Disable Resync- since the TBC is handling the sync. With a reliable capture card, it'll be good.
msgohan 04-04-2022 09:46 PM
For my most frequently used HDMI capture card, "Correct video timing" prevents a few inserts that always appear at the very start of the capture when it's disabled.
In my screenshot, it's already manually disabled by the "Do not resync" radio button above, so I don't feel the need to check the Auto Disable box.
KhAoS182 04-05-2022 02:10 AM
KhAoS182 settings:
Attachment 14997
My settings:
Attachment 14998
No… 0 Dropoed or inserted frames
KhAoS182 04-05-2022 02:12 AM
Originally Posted by lordsmurf (Post 83939)
- what card?
- attach images to the forum, do not hotlink.
ATI 600 usb
msgohan 04-05-2022 04:05 AM
What happens if you try my settings instead?
KhAoS182 04-05-2022 05:41 AM
Today I will try your settings, thanks.
Why is necessary the "Force audio clock when audio playback is enabled" ?
Once the capture is finished (I will do it with a 30-minute tape) I have to check the audio is synchronized to the video and the audio doesn't slow down to adapt to the video.
msgohan 04-05-2022 06:05 AM
You can skip that if you want. You should always disable Audio Preview in VDub while capturing anyway.
KhAoS182 04-05-2022 06:38 AM
Two days ago I tried the "Do not resync" option and the audio slowed down somewhere in the capture.
msgohan 04-05-2022 07:37 AM
You do have Audio -> Enable audio playback disabled, correct?
KhAoS182 04-05-2022 07:39 AM
Yes! Is disabled. Is there an option that has to be enabled and disabled outside VirtualDub?
msgohan 04-05-2022 10:23 AM
Troubleshooting step:
Assuming the DMR-ES15's DVD drive works, play back a disc and capture that instead of capturing VHS. This will at least eliminate one variable: the generated analog signal while playing the DVD will for sure be up to standard.
