How to fix audio desync, audio earlier than video?
I'm capturing using a premium capture kit Lord Smurf put together (VCR + Frame TBC) via VirtualDub using the following settings that Lord Smurf helped me work out.
I noticed VirtualDub inserted some frames (only 21 over the course of the entire tape), but no frames were dropped. The audio lag seems to be within a second or so, so maybe the inserted frames are enough to make it feel really off. Can someone help me determine why VirtualDub is inserting frames, which is presumably why the audio and video are desynced? I'm open to the possibility that there are other issues, but it's definitely not dropped frames (or virtualdub is lying). My "Settings for Dummies" notes: 1) Launch Lord Smurf's version of VirtualDub 1.9.11 (after installing Huffyuv) 2) File > Capture AVI... 3) Press F2 to set the destination and filename 4) Confirm Device selected is ATI TV Wonder USB 2.0 (DirectShow) 5) Confirm Video > Video source is set to Video SVideo 6) Confirm Capture > Settings is set to a frame rate of 29.9700 7) Go to Video > Compression... and ensure Huffyuv v2.1.1 is selected 8) Go to Audio > VOlume Meter to turn it on. 9) Go to Video > Set custom format... and ensure it is set to 720, 480, YUY2 YUV 4:2:2 interleaved 10 Go to Capture > Timing and make sure "Automatically disable resync when integrated audio/video capture is detected" is checked. In the same menu, uncheck "Force audio clock when audio playback is enabled" Also, "Enable audio playback" is disabled. |
I have the same issue
Although with your card is probably better to stay with VirtualDub and fix the issues of asynch audio/video there, you can give to AmarecTV a try
You already have one of the best capture card, Blackmagic cards are not recommended for a capture through their analog inputs.
I know lollo2, but I've been trying to make it work for months and there is no way, I don't know what else to try. |
If I understand correctly your post on videohelp forum, you have many inserted frames using Windows XP, ATI USB 600 and AmarecTV.
The inserted frames may depend on the specific tape: I have one tape that showed the same single inserted frame exactley at the same point across 4 different captures! They may also depend on the hardware. From the PC side, you should capture to a separate drive than the drive where the OS in installed, disable antivirus, disable Wifi, disable disk indexing and disk cashing, disable internet access, terminate all processes running in background, double check the drivers of the cards and of the other components in use, remove any other usb device connected that is not the capture card, check the USB port, etc. The lossless SD capture flow is not requiring a high bandwidth, and modern disks and PCs are adequate for that, but it must be sustained without interruption for a long time. I do not even move the mouse while I am capturing. |
Do the many inserted frames appear in all of your tapes and captures?
If you capture the same segment more times, do the inserted frames appear at the same position in all captures? |
After testing various options it looks like my solution may be using the "do not resync" timing option. I captured a full film with it disabled. The sync looked good, and only single-digit frames were inserted (8, I think). Things were way off, by 1-2 seconds, when using the "Sync audio to video by resampling the audio to a faster or slower rate" option, and more frames were inserted (like 50+).
Now, this may not be an option for those not using a frame TBC, but my JVC VCR with line TBC + frame TBC + ATI USB 600 on Windows 7 seems to prefer this config. I plan to do more testing to confirm, but so far so good... Also, this may be "duh" to some of you, but in case it isn't... Searching the guide linked below for "do not resync" was helpful for me. Lots of great info there. https://www.digitalfaq.com/forum/vid...-settings.html |
2 Attachment(s)
Scratch what I said before. I did another test with sync disabled and the audio was totally desynced from the video again. I've attached screenshots of capture results and settings for both attempts.
I normally wouldn't keep posting back-to-back, but I don't see the option to edit posts. I wanted to rule out hard drive IO of my 2TB drive, so I saved some more test clips to my SSD (which isn't big enough for a full tape, but can handle a few clips). The clips were about 30 seconds a piece. The first clip looked in-sync. The second clip looked good as well. The third clip was totally off where the audio is once again a second or two ahead of the video.
This issue is maddening. Whether or not audio/video is synced is totally inconsistent, and because none of my tests have repeatable results I don't know how to nail down what's going on. |
I did learn ONE thing, which is that USB activity absolutely has an effect on inserted frames. I have a USB switch that swaps my keyboard, mouse, and webcam between my work and home PCs. Every time I would swap back and forth between them, I'd see a surge in inserted frames. Within a couple of minutes I could easily top 200 inserted frames just jumping back and forth between the two. But, even with absolutely nothing else going on, if I press F6 to initiate a capture, VirtualDub hangs for a moment, then I ALWAYS getting inserted frames between 8 and 20+ right at the beginning of the capture (even if I set the process priority to "High" in task manager). I tried initiating a capture, then waiting to play the tape until after VirtualDub was mid-capture, but the audio is still off, so my best guess is that the inserted frames at the beginning are pushing back the tape's video as well (Tell me if I'm dead wrong here, but even if I am, the fact remains that the audio is ahead of the video). I've just about tried everything I know to try... |
Following. I've just started this journey recently but am having a similar issue and trying to make heads or tails of it. Haven't tried AmarecTV but it's worth a shot. I've been trying various recommended configurations in VirtualDub so far with no success.
Currently working on 8MM tapes using a Sony DCR-TRV350 going to an I-O Data GV-USB2. Video looks great but audio is wildly out of sync, particularly towards the end of the tape. And this is with a seemingly good quality tape (2006) with zero reported dropped frames. I'm starting to think it's the card but others have reported success with the GV-USB2 so idk. I've also got a JVC SR-V10U but haven't started on my VHS tapes yet. Planning on testing that out to narrow down possible sources of error. Anyway, please update if you find something that works for you. I'll do the same. |
AmaRecTV did it. Wish I had tried it earlier. Everything seems to be working smoothly.
Thanks for the the guide FleshWound - lots of helpful material in there. |
I'm desperate, I will pay €100 to whoever helps me solve the problem with my captures, I don't know if it is some component of my capture computer, configuration, etc. Thanks!
