Lagarith crashes on capture with VirtualDub?
1 Attachment(s)
Is there a known fix for Lagarith crashing in Virtualdub right as the capture is started when using that codec?
The error is: "An out of bounds memory access (access violation) occurred in module 'lagarith' Photo also attached of the screen. I am pretty sure lots of users use Windows 32 bit and virtualdub for lagarith captures, so wondering how I get around this. I thought about just removing 2gb of ram from the computer and seeing if that fixes it, but I'd prefer not to if there's a better way, and I'm also thinking that probably will not fix it, but I may give that a go if nothing else works. Setup: Asrock 4CoreDualVSTA with 4gb of ram and 2.66ghz quad core2extreme (underclocked to 2.4ghz) AGP AIW 9000 Pro Virtualdub 1.9.11 from preloaded package with filters downloaded from digitalfaq Windows XP 32 bit Of note, the other bandwidth heavy codecs such as ffdshow, Huffy v2.1.1, and "no compression" all function fine on the machine. Thanks in advance! |
FYI, my personal XP AIW system uses 4CoreDual-SATA with 4gb RAM. It's fine.
I'm actually currently redoing it with SSD, and installing XP Integral on it. The SATA HDD sometimes causes system hang, but SSD does not. And then ditching IDE for boot. New silent PSU, rip out most fans. I only capture Huffyuv, and almost nothing else is installed. Pure capture box. |
