| aramkolt |
09-29-2024 09:19 AM |
I looked up the BVW-75, that's a pretty cool machine by the looks of it!
It appears NOT to use a rotary transformer to move the signals out of the spinning head which I always wondered if produced a better result - You'll see there's a post that sticks out of the top of the head and it has several brushes that pick up the video signals off of that post. Could be that is more or less standard for Betacam, but I haven't seen it too often for VHS other than in some early JVC professional machines.
Anyhow, looks like the BVW-75 already has a TBC in it (which I'm guessing is some combination of line and frame), so the BMD products should do a good job with it. The Intensity Shuttle would be going straight to USB3 or Thunderbolt, so that'll save you a device in the chain for actual capture over having the Mini Converter give you SDI. BMD products get a bad rep here mainly because they don't handle consumer formats or timebase errors well, but I don't think that applies here.
If you plan to do editing with the footage afterwords with a ProRes intermediate, you could consider something like the AJA Ki Pro which has component inputs (and even balanced audio inputs) to capture to ProRes 442 HQ directly to a hard drive. While ProRes HQ isn't lossless, it is supposed to be "visually lossless", and it's basically your whole capture PC in one small box. BMD makes hard drive and SD-card recorders as well that also accept analog component (also storing as ProRes), I just have seen a lot more parts/failed units on ebay to suggest that they might not be as reliable in the long run.
Lossless probably has an advantage over ProRes HQ if you plan to deinterlace the content before putting it into your linear editor, but I doubt you'll visually be able to tell a difference unless you are dealing with extremely rapid-motion scenes. One possible advantage of ProRes capture is that it uses 10 bit color whereas Lossless captures are typically 8 bit. If you have scenes where there are mainly solid colors that slowly change to a different color (like sunsets/sky) you can get banding of color with 8 bit whereas you won't with 10 bit. Depending on the deinterlacer, it might truncate the color space back down to 8 bit anyway which kind of removes the advantage of capturing in 10 bit.
The other (possibly) annoying thing about AJA and BMD recorders is that many record to Mac formatted drives, so you'll either need to buy/install something like Paragon HFS+ for Windows to pull the contents from the drive unless you have a Mac that you are using as the destination or intermediate device to copy the files to first.
