-   Encode, Convert for discs (https://www.digitalfaq.com/forum/video-conversion/)
-   -   Play NTSC DVD in a Region 2 DVD machine? (https://www.digitalfaq.com/forum/video-conversion/10983-play-ntsc-dvd.html)
ELinder 09-11-2020 03:55 PM
I've been asked to make DVD disks that will play in a Region 2 DVD player from the NTSC DVDs that I have set up. I've read thru the guides and searched, and it's fairly clear that the NTSC video will be playable on modern PAL Region 2 DVD machines. I have DVD Studio Pro set up to make region free disks anyway, so that's not a problem. However, I'm assuming that the NTSC encoded disk menus and images are also not a problem across regions?
So basically I just send them my normal NTSC DVD and they should be able to play them?
Thanks,
Erich
lordsmurf 09-11-2020 04:00 PM
NTSC DVDs play in PAL DVD players as-is, no conversion required.
Only region coding is an issue, but there is no region coding on homemade/burned discs.
BTW, PAL DVDs play in most NTSC DVD players, too! Most DVD players are made with worldwide kits from a few manufacturers. Most have region locking in hidden menus, sometimes firmware, but it's fairly easy to bypass. Macrovision is sometimes disabled this way as well.
ELinder 09-11-2020 05:25 PM
Thanks for the quick confirmation LS!
Erich
dpalomaki 09-11-2020 08:05 PM
One point to keep in mind. While one can change the internal region setting for a DVD drive, some drives have a limit on the number of times that the region can be changed.
