Using Womble MPEG Wizard to edit the video, I'm having problems with the "sound line editor".
Using the sound line editor, I would cut, (not delete, just cut between the area where I want to edit the audio) use the sound line editor to fade either in or out using markers (pionts) and then the audio would not play during playback. Or, I should say, sometimes the audio would play, and sometimes not. After each audio edit, I would save the file, so saving is not the problem. It seems this is sporadic! - jrnyhead |
I've never used this program, but I'll look at a trial (if one exists) and see if I can recreate the issue.
I do know that the fade utilities on Womble MPEG-VCR would often crash my Windows ME system, but work fine on my Windows XP Pro system. |
Lordsmurf:"I've never used this program, but I'll look at a trial (if one exists) and see if I can recreate the issue.
I do know that the fade utilities on Womble MPEG-VCR would often crash my Windows ME system, but work fine on my Windows XP Pro system." </font> Did you get a chance to try to recreat this audio fade problem? There is a 30 trial on Womble's website. |
I've not been able to re-create the problem. Still testing.
