-   -   Is this ghosting, ringing, oversharpening? (https://www.digitalfaq.com/forum/video-restore/14119-ghosting-ringing-oversharpening.html)
iseevisions 02-17-2024 12:50 PM
1 Attachment(s)
This is captured from a PAL VHS with a 1999 analog cable TV program recorded on.
Attachment 17478
What is best described as the edge issue?
Also what avisynth/vapoursynth filter/setting is best used to fix this?
aramkolt 02-17-2024 05:18 PM
If your capture setup allows for it, try changing the YC delay. If the chroma isn't aligned with luma exactly (which is actually fairly common) you'll see a single ghost image shifted usually to the right, more noticeable on brighter objects or at edges of high contrast areas. Also, is this a composite or S-Video Capture from the VCR? Not sure if that matters, but you might try capturing whichever you aren't currently capturing and seeing if there's a difference in the ghosting.
Feedbucket 02-17-2024 09:12 PM
Can probably be mitigated with something like vsLGhost.
lordsmurf 02-17-2024 10:15 PM
This video still sample here has "halo", or "ringing", not chroma offset. :2cents:
iseevisions 02-18-2024 04:07 AM
1 Attachment(s)
Captured over s-video from a JVC HR S6800EH VCR to a matrox MXO2 mini.
I could also test from composite to see..., or another VCR perhaps.
Originally Posted by Feedbucket (Post 94808)
vsLGhost
Yes I was already testing with several filters/settings like:
clip = haf. MCTemporalDenoise(clip,settings="low", edgeclean=True, stabilize=False, maxr=2)
clip = haf.DeHalo_alpha(clip)
clip = core.lghost.LGhost(clip, mode=1, shift=6, intensity=-10)
clip = haf.YAHR(clip)
But I can't get it to go away...
Attached a short sample video for anyone interested to play with:
Selur 02-18-2024 07:34 AM
You might also want to try, BindDeHalo3 (and adjust the settings)
Feedbucket 02-18-2024 10:04 AM
1 Attachment(s)
How about
mode=1, shift=2, intensity=-80
for LGhost? Softens the image but my understanding is oversharpening is what causes this in the first place.
iseevisions 02-19-2024 08:21 AM
Yes, that seems to make it less noticeable.
Not sure where the oversharpening comes from.. could be recorded that way back in the day or a problem with the VCR.
Have to change hardware and recapture to find out...
