-   Website and Server Troubleshooting (https://www.digitalfaq.com/forum/web-tech/)
-   -   Mandrill SMTP global server settings? (https://www.digitalfaq.com/forum/web-tech/5347-mandrill-smtp-global.html)
mcowen64 09-11-2013 10:38 AM
Is there any "account global" setting I can use for the Mandrill SMTP settings, or do I have to do every app, account, etc. separately?
This question was asked via email. Site Staff no longer answer tech questions via email, so that others may read and benefit from our expertise. Please continue the conversation here. Either login or join as a Free Member, and we can continue troubleshooting your video, photo or web related issue. Thanks for understanding our tech Q&A policies.
kpmedia 09-11-2013 10:39 AM
I'm not sure what you're referring to.
It usually works like this.
1. You setup a script on a domain (public or not), to send mail
2. The script has options, on of which is which server to send from. You pluging SMTP info here.
3. When using Mandrill (or other SMTP service), that's the details that gets plugged into the form/options.
There's zero server side. It's all domain side (hosting client side), per site.
mcowen64 09-11-2013 10:39 AM
I was thinking in terms of a "default mailer" on the server. I know there's an <account name>@serve identity for anything that sends via the server itself. I didn't know if in our configuration if there was a way to alter that at the domain level for the occasional message that might get sent directly from the server.
kpmedia 09-11-2013 10:40 AM
None of your scripts should send directly from the server. If you find one, patch it use SMTP. Most swapped to that around 2006 or so. Off hand, I don't know what would send with that as the from email.
mcowen64 09-11-2013 10:40 AM
Right now, the help desk in using its PHP mailer function identifies itself that way. No settings in that mode at all. I'm in the process of setting up Mandrill, and wanted to be sure I wasn't overlooking something.
It has SMTP.
http://osticket.com/wiki/Email_Settings
