How to burn CD/DVD ISO files in Windows or Mac OS X [GUIDE]
6 Attachment(s)
[QUICK GUIDE]
Need to burn an ISO to CD or DVD, and don't know what software to use, or how to use it? Either use the freeware Imgburn in Windows, or the freeware SimplyBurns in Mac OS X. For convenience, both SimplyBurn and ImgBurn have been attached to this post. (ImgBurn has an installer; SimplyBurns is inside a zip, and then simply drop the unzipped program into the Applications folder.) Both programs properly burn CDs/DVDs to the correct audio/video disc specifications. ___ NOTE: You must be logged as a Free Member or Premium Member to view images or download files. It's free, register now. We never spam or sell your address. Register now or login. ___ Instructions for SimplyBurns - Mac OS X 1. Select 'Burn Image' from the initial screen given when the program starts. Attachment 1611 2. Choose your image file. Burn. (Note: The ONLY downside to SimplyBurns is that you cannot select your burn speed. It will likely default to max burning speed. Although not ideal, it will still generally be okay on high quality blank DVD media like Verbatim/Mitsubishi or Taiyo Yuden.) Attachment 1612 Easy! [8~2] Instructions for Imgburn - Windows Note: Imgburn has been tested to work with at least Windows XP, Vista, Win7, Server 2003/2008. 1. Imgburn opens with the "easy mode picker" (Ez-Mode) menu, and you select the option to burn an image to a disc. Attachment 1609 2. With the spyglass folder icon, open your ISO image file. Pick your burning speed (8x or 12x on 16x DVD-R), and then burn with the big unlabeled button. (No disc was in my drive when making this guide, so it's not "lit up"; instead it's shown as "grayed out".) Attachment 1610 Easy! :) |
When I click "write" it takes me to the dvd workshop folder, and my project that I just made in Workshop is there, so I double click it, and it takes me to a screen that has these folders in it..disc build, audio ts, capture, dws_ts, video_ts.
When I double click the VIDEO_TS folder, there is a file inside of it that says, VIDEO_TS.IFO so I highlight it, click open (to try and burn it) and an error message pops up that says "You're in the wrong "Mode" for burning DVD video files. Switch to "Build" Mode and then try again. So, I go to "Build Mode" (which is the same mode I use for copying DVDs) and I'm able to burn the DVD from there. I guess it's not a big deal since the project still burns to DVD, but I haven't made a DVD in a long time, and I'm just getting back into it, and I always thought I had to go to the "Write" option to burn a DVD that I made, and that's even what was said to do in this post. I just wanted some clarification on that. Thanks. |
I think you went too far into the folder.
Try just putting the AUDIO_TS and VIDEO_TS folders in write mode. I noticed with the new IMGBURN, which could have been true with the older ones that I can place the entire folder in write mode....the one that has the above folders in it. Then it is ready to write to disc. You have to choose "write image file to disc" if you have image file (ISO) You have to choose "write files/folders to disc if you have folders(VIDEO_TS, AUDIO_TS). |
In this case, it's exactly as stated -- you're using the wrong mode. The guide in the first post was specifically created for burning ISO image files to DVD-R, DVD+R or DVD+R DL media. Your DVD Workshop 2 project was not authored as an ISO file, but to a folder set (VIDEO_TS + AUDIO_TS + other unnecessary "housekeeping" data folders created by DVDWS2). To burn folder, and not ISO files, you must use Build Mode. I know this has been covered in other guides and posts on the site, but to quickly review that process one more time:
