You are right of course, but the tradeoff to use a TBC is worth it. I believe there are devices that can skip this step, for example dvd recorders use a tbc on input and store directly to a digital file. There's probably other ways to do it, for example to use a camcorder as the capture, and record through compressed DV. Another way would be to use an AV receiver, though in that case you are probably looking at recording HDMI as output (which is complicated).
Yes, that's easy! (my new catchphrase :)
http://www.digitalfaq.com/forum/vide...al-output.html Do a search for "using received as tbc" and you'll find more references. I can't tell you if it has 3d comb as well, but there's a way to do that in software, live if need be. I answered the general technique recently. http://www.digitalfaq.com/forum/vide...ctorscope.html Instead of using the setup for viewing a vectorscope, you would paste a script to do decomb. There's quite a few of them, and I have used some that do work. |
3D Comb Filters are only used on composite video input to separate the chroma and luma portions of the video. If using S-Video for capture, you don't need one at all. The TBC found in Sony camcorders is a very good unit, there isn't any noticeable signal degradation and it does a great job of stabilizing the video.
we should have a list of the good HI-8 cameras, like LordSmurfs' VHS list
these Sonys are S-video with stereo out: CCD-TRV62 CCD-TRV65 CCD-TRV66 CCD-TRV70 CCD-TRV72 CCD-TRV82 CCD-TRV85 CCD-TRV87 CCD-TRV99 CCD-TRV101 CCD-TRV615 im sure i missed some -if you know of more ad them |
CCD-TR940 and CCD-TR917 do stereo audio too. All Digital-8 camcorders with analog playback (I'll compile a list of the ones to avoid that lack this feature) along with the GV-D200 and GV-D800 Video Walkmans can also play back stereo Hi-8 tapes too.
do the 940 , 917 and the walkmans have S-video outs as well?
The following Digital 8 camcorder models can NOT play back analog Video-8/Hi-8 recordings. They only play and record Digital-8 tapes. They also lack firewire analog pass-through capabilities.
DCR-TRV130 (2001) DCR-TRV140 (2002) DCR-TRV250 (2003) DCR-TRV260/265 (2004) DCR-TRV280 (2005-06) |
i also believe these are S-video/stereo:
ccd-trv75 ccd-trv93 ccd-trv715 ccd-trv815 does anyone know offhand if a CCD-TRV101 has TBC & DNR? |
The CCD-TRV101 (1996, stereo, non-XR) has the TBC/DNR function, it also one of the few HandyCams that recorded a datecode to the tape similar to how DV does it. You can recall the date and time of the recording with the touch of a button! |
My focus would be on the TBC. As long as the camera has a TBC, and is in good shape, I'd be happy.
Composite will suffice; s-video is better, but it's not as big a deal with 8mm formats. Stereo audio is a non-issue, because it's not like you weren't recording from a single location anyway. That's my vote. :) |
My camera has arrived:
http://www.ebay.com/itm/110810443091...84.m1436.l2649 I think it works ok as far as playback is concerned. However, there's one little thing. When I go to menu and adjust the settings, there's a wheel to move the selection up and down. If I roll the wheel up, the selection is supposed to move up, and if I roll the wheel down, the selection is supposed to move down. It's not always the case. Sometimes the selection jumps randomly. Other than that I didn't find any problems so far. I can return it, but I think I want to keep it. Yet I'd like to ask whether the experts here on this forum think that this is a minor issue or not. Oh, and by the way, I tried test capture with TBC on and off and found that the colors of the same footage slightly differ from each other. I found that with TBC off they are more natural. |
i certainly pays to know what ones to look for.
while everybody on ebay was fighting over the more widely known models and IMO paying way too much, i stole a CCD-TRV101 - mint with a Sony case, brand new battery, 2 new sealed Hi-8 tapes and even a Sony 8mm tape rewinder - $53 shipped i used it to capture some tapes i had previously done with a Minolta Hi-8 camera. what a difference!!! - the Sony looks 100 times better |
2 Attachment(s)
I'd like to post 2 images. They were done from the same Hi8 cassette.
First work flow was Sony CCD-TR93 -> Compro VideoMate via Composite -> Huffyuv/704x480. Compro was equipped by WDM drivers from Compro. Second work flow was Sony CCD TRV65 -> LifeView FlyVideo via S-Video -> Huffyuv/704x480. I didn't use drivers from LifefeView. I used the reference drivers from Philips directly. It is obvious that the 2nd image is much clearer, has more details and has much less White Peak spread out. What contributes to the difference is obviously difference between the quality of playback on these camcorders, Composite vs S-Video and WDM capture drivers from Compro vs capture drivers from Philips. Both capture cards are based on Phlips SAA7135 chip. Admin refused to unhide hidden content nothing will help to see hidden content |
