Quantcast Capturing 528x480 Resolution from VHS with WinTV Go - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Video Capturing / Recording
08-29-2002, 01:32 PM
rendalunit rendalunit is offline
I just captured "Wrongfully accused" at 528x480 from vhs with wintv go. I didn't drop any more frames than I would have with 352x480 too. Also I'm using smart smoother instead of flaxen vhs because it seems a lot faster and just as good results.
Is it worthwhile to cap at this resolution instead of a lower res and then resizing for kvcdx3?
thanks
Site Staff / Ad Manager
08-29-2002, 02:27 PM
kwag kwag is offline
thanks
Hi ren,
If your capture was succesful, you should be able to encode at exactly that resolution, which fits exactly the KVCDx3 size
I believe you're going to get sharper picture than if you had captured at 352x480.
Let me know how your encode looks!
-kwag
08-29-2002, 02:34 PM
el_mero_zooter el_mero_zooter is offline
Send a message via MSN to el_mero_zooter
R,
ideally you'd want to always capp at the res you'd want to encode (provided you're getting both fields) and then resize down or stay at that rez. I wouldnt Upsize as you'd lose quality. I'd say try it at XXXTreme resolution (x3) and as long as your frame droppage isnt too bad, then go for it.
ztr
08-29-2002, 03:25 PM
thanx kwag & ztr,
I dropped about 50 frames out of the whole thing ( which to me doesn't seem too bad ) . So far it's looking pretty good in the tmpg preview window
Something strange happened though. I tried to frameserve my capture through avisynth with VDub and in tmpg the picture was black and white and also scrambled So now I'm not using and avs with vdub. Have any idea what this is about?
ren
08-29-2002, 03:41 PM
thanx kwag & ztr,
ren
Were you able to read the .avs directly with TMPEG without Vdub? I mean, did it look correct on TMPEG while encoding?
Also, are you using the btwincap drivers with your capture card?
-kwag
08-29-2002, 03:56 PM
hey kwag,
I didn't try loading the .avs directly into tmpgenc I loaded CAPTURE.AVI into FitCD made the avs- loaded the avs into VDub then frameserved to tmpg. It was all screwed up.
I'll try to duplicate the problem after the encodings finished.
thx,
ren
Intermediate resolution between 352x240 and 528x480 ? jim620 Video Encoding and Conversion 20 04-24-2004 07:54 AM
do i need to increase the resolution to 544x480 or 528x480? enximex Video Encoding and Conversion 6 11-09-2003 11:44 AM
Avisynth: Changes for MA script for 528x480/576 resolution? audioslave Avisynth Scripting 21 07-31-2003 01:46 PM
Star Wars on one kvcd with 528x480 resolution? Adder Video Encoding and Conversion 16 02-26-2003 08:37 AM
Capturing with Wintv - splits the files after 2gb? figgymanna Video Capturing / Recording 1 12-24-2002 04:13 PM
All times are GMT -5. The time now is 07:58 AM  —  vBulletin © Jelsoft Enterprises Ltd
