Quantcast DVD2one 1.5.0 is Available - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Authoring VCD, DVD, Blu-ray
07-13-2004, 10:19 PM
black prince black prince is offline
@anyone,
http://www.dvd2one.com/forum/viewtopic.php?t=512
This release seems to be confusing with low, Med, High compression
distribution. Maybe someone can tell us how it suppose to work
-BP
Site Staff / Ad Manager
07-14-2004, 04:52 AM
Zyphon Zyphon is offline
Hi bp,
reading that post in their forum it does sound confusing, unfortunately I dont use DVD2One as I prefer using DVDShrink for backing up my DVD's.
__________________
Regards.
Michael.
07-14-2004, 07:36 AM
Dialhot Dialhot is offline
Exactly the same thing : I did not understand anything on their description page so I didn't even DL the trial release.
07-17-2004, 04:23 PM
Update:
DVD dual-layer are coming soon, so DVD+-R will disappear. The one click
transcoders will also disappear. You'll be able to fully backup your
purchased DVD's (menus, directors cuts,etc.) without any problems.
As for DVD2one v1.5.0, a preview (low,med,high) would help to decide
which compression is best to use. This may be moot, once DVD dual-layer
arrives.
-BP
07-17-2004, 04:29 PM
Why do you want them to disapear ? There will be 2layer disc in both formats ! (even is only +R has delivered its withe book till now).
The one click
Unfortunally false. Pre-recorded DVD can handle 9.2GB where recordable ones will be limited to 8.7GB.
And do not expect to put a DVD not completly full on a DVD+R eitheir because the layer break won't fall at the same place.
So the transcoder will still be necessary. Only the compression will be a lot more closer to 95% than 70%
07-17-2004, 06:07 PM
Thanks for that info Phil I didn't know that about the new dual layer DVD-R's.
__________________
Regards.
Michael.
DVD2One v1.3.0 is available black prince Blank Media / Burning Discs 8 10-05-2003 03:56 PM
DVD2One 1.2.0 is out black prince Blank Media / Burning Discs 0 06-19-2003 07:24 AM
DVD2one v 1.1.1 is out black prince Blank Media / Burning Discs 4 03-21-2003 11:45 AM
DVD2ONE v1.0.1 is out!!! syk2c11 Video Encoding and Conversion 0 02-18-2003 11:44 PM
About DVD2ONE GetUp Video Encoding and Conversion 20 01-31-2003 10:49 AM
All times are GMT -5. The time now is 04:25 PM  —  vBulletin © Jelsoft Enterprises Ltd
