Quantcast Reauthoring DVD to Remove Trailers, etc? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Authoring VCD, DVD, Blu-ray
09-13-2004, 06:37 PM
kev23m kev23m is offline
I backed up the full dvd to the hdd.
Now contents atre vts -01 /02/03
On startup it playes Vts_01_1.vob which is an ad , vts_01_0.vob has the menus.
Vts_02 is the main Movie
Vts_03 is the trailer.
Now i wanna get rid of the ad(vts_01_1.vob) and the trailer (Vts_03) and make changes so that it auto plays Vts_01_0.vob and edit the menu so that it does not show trailer option.
How would i do it?
Site Staff / Ad Manager
09-14-2004, 06:42 AM
Dialhot Dialhot is offline
MenuEdit or DVDRemake.
09-14-2004, 08:01 AM
Thanks DvDRemake does the jon nicely.
09-14-2004, 10:11 AM
incredible incredible is offline
Send a message via ICQ to incredible
You should also have a look at VOBblanker, as its able beside deleting Titlesets, cropping of streams in cells (like in ShrinkDVD)! by keeping the Main Menue etc.
09-14-2004, 01:04 PM
Will definetly try it.
Thanks Inc.
09-14-2004, 03:02 PM
Damn the menu itself is 1gb .
No need for Automated tool , rather do it manually and strip the motion clip from the original dvd and do a nice simple menu .
The difference. Using DvdRB with save 50% from etc's and resize to half d1 for etc's. Main movie prediction at bitrate 64-3500 Q = 56.
Now I am doing just the movie with a 12mb clip for menu and its 300-5000 and Q=21.
Na too much sacrifice for the menu , rather watch just the movie , hell it's a backup.
09-14-2004, 04:35 PM
jorel jorel is offline
ot in
for my taste menu is cool but a little irrelevant and using my short knowledge i do like this:
encode 1 to 3 main movies with one audio track, no subs or permanents subs for 1 media target.
author in tmpgencdvdauthor and build menu and chapters.
why?..simple.
when i use the media in standalone,
i don't want the menu and the first movie start alone(auto-play).
IF i want to see the another movie then i call the menu and choose what from that 3 movies i select..if don't , the 3 movies will play to the end.
after the 3 movies play then came the menu and the dvd don't start everything again without my commandment!
if you build a menu to play in the begining, you need to choose your options but, if the media autoplay like i do, you call the menu only if you want to change the movie!
then...it's very cool for my taste and simple to author!
ot out!
09-16-2004, 12:58 AM
Yeah I tried Tmpgenc Dvd Author , very simple and nice.
I got menu's made with chapter display , only one problem .
How do i change the color combination for selection , whenever any option is selected it goes yellow and on play goes red.
Thanks.
Edit:: got Tmpenc Dvd Author 1.6 problem solved.
Multishrink batch processing for DVD Shrink (reauthoring DVDs) Zyphon Authoring VCD, DVD, Blu-ray 5 11-11-2005 08:32 PM
Avisynth: Remove logo? zagor Avisynth Scripting 6 07-03-2005 09:19 PM
How to remove extras on DVD? fdonline Video Encoding and Conversion 8 11-07-2004 04:54 PM
Avisynth: Remove dirt? maninwales Avisynth Scripting 1 10-17-2004 03:20 PM
Keeping original dvd menus when reauthoring? andybno1 Authoring VCD, DVD, Blu-ray 7 08-27-2004 09:05 AM
All times are GMT -5. The time now is 09:03 PM  —  vBulletin © Jelsoft Enterprises Ltd
