Quantcast Capturing: Should I Deinterlace, or Telecide Without Decimating? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Video Capturing / Recording
01-09-2005, 11:37 PM
nicksteel nicksteel is offline
I am capturing the tv series "24" with PVR-250 at MPEG2 12.0MBit/sec (CBR) analog.
In Vdub, I have a repeating pattern of 3 clean frames followed by 2 interlaced frames. All frames appear to have movement.
I will be putting (4) 42 minute episodes on each DVD.
Should I deinterlace, or Telecide without Decimating?
Given it is a TV capture, should I use DVD Full or DVD Half?
Should I use Phil's script (below) or something else?
Mpeg2Source("H:\24\4_07A08A\4_0708.d2v")
Telecide(order=1, guide=1, gthresh=10, post=2, vthresh=50, dthresh=7, blend=false, show=false)
Decimate(cycle=5, mode=0, threshold=0, threshold2=3, quality=2, show=false)
Blockbuster(method="noise",detail_min=1,detail_max =8,variance=0.3,seed=5823)
Deen()
GripCrop(704, 480, source_anamorphic=false)
GripSize(resizer="LanczosResize")
Undot()
TemporalSoften(2,7,7,3,2)
DCTFilter(1,1,1,1,1,1,0.5,0)
Blockbuster(method="noise",detail_min=1,detail_max =10,variance=0.5,seed=5623)
GripBorders()
LetterBox(16, 16, 16, 16)
EDITED: Sorry, it is in pattern, so I will Telecide() and Decimate(). Would you use above script?
Site Staff / Ad Manager
Avisynth: Telecide won't play KVCD files? jzhao66 Avisynth Scripting 3 07-11-2005 07:19 PM
KVCD: Confused by Telecide kev23m Video Encoding and Conversion 9 04-23-2004 11:18 PM
Telecide() and Decimate() causes skips? nicksteel Video Encoding and Conversion 6 05-14-2003 08:08 AM
KVCD: To deinterlace or not to deinterlace? girv Video Encoding and Conversion 1 01-20-2003 10:54 AM
Avisynth: Problems with telecide and decimate conquest10 Avisynth Scripting 2 01-01-2003 11:28 PM
All times are GMT -5. The time now is 04:51 PM  —  vBulletin © Jelsoft Enterprises Ltd
