Quantcast Avisynth: Frameserve to a Remote PC? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Avisynth Scripting
09-01-2005, 08:58 AM
scrappy scrappy is offline
Firstly I'm not sure if this is the right place for this, if not then I'm sure someone will move it
Ok, what I want to know is, is it possible to take an AviSynth script and run it on a local pc to pre-process the video and then frameserve that to an encoder running on another remote pc. Reason been I have a friend who's offered me the use of a dual opteron box for encoding, only its like 200 miles from me
It's running Linux (Debian 64bit edition), so I would assume mencoder would be the best encoder to use on it. I am proficient with Linux/Unix systems so grabbing stuff and compiling it etc ain't a problem, just not sure if this is possible or what I would need.
Any suggestions greatly appreciated
__________________
Mark
Site Staff / Ad Manager
09-01-2005, 09:06 AM
kwag kwag is offline
Then you can forget it
If that computer was on your LAN, then it wouldn't be a problem.
Being far away, you would have to frameserve the raw video to his machine, and then after that huge transfer (encode), go pick up the encoded file 200 miles away or transfer it back
By that time, you probably have already encoded 10 movies on your single CPU machine
-kwag
09-01-2005, 09:16 AM
So it is possible to frameserve avisynth from a windows box to a linux box then? I have a couple of Gentoo servers on my lan both P4 2.8 (prescott) boxes, you've got me thinking now
__________________
Mark
Remote customer support black prince Computers 1 11-17-2005 11:51 AM
Avisynth: Unusual frameserve/cut/demux issue silverspoonjackass Avisynth Scripting 2 06-23-2004 04:35 PM
Avisynth: frameserve with avisynth to CCE? Dang Donkey Avisynth Scripting 4 10-14-2002 05:45 PM
Sound out of sync pressing next on the remote? emale00 Players, DVRs, Media Centers 1 08-12-2002 11:45 AM
Avisynth: Frameserve only sound from a movie? JcF Avisynth Scripting 2 07-29-2002 09:47 AM
All times are GMT -5. The time now is 02:55 PM  —  vBulletin © Jelsoft Enterprises Ltd
