01-25-2006, 10:49 PM
Whats a good sharpening filter to apply for DVD source, I could find asharp and warpsharp, any suggestions on a decent parameters for those ??
Site Staff / Ad Manager
01-25-2006, 10:57 PM
Try asharp(1, 4) or asharp(1, 3)
If you find it too strong, lower the second parameter.
-kwag
01-26-2006, 02:53 AM
-kwag
to be used before or after denoising, i tend to use removegrain with asharp ???
01-26-2006, 04:54 AM
-kwag
Always denoise before you sharpen. If you don't, the noise will be sharpenend and that's not what we want.
Have you already looked into lremovedust + limitedsharpen? These are currently the best denoiser and detail enhancer IMO.
01-26-2006, 05:55 AM
+1.
I did some test this w-e because I have some blury sources that absolutly need a detail enhancer. I'm crying about the slowness of limitedsharpen but nothign can beat it.
I tried : asharp(1,3) asharp(1,4) asharp(2,4) asharp(2,3) msharpen() and all parameters of limitedsharpen (edgemode, wide, Smode=4, Lmode=1, Lmode=2...). Nothing better than simply use the default parameters and of course each time, denoise before with remove dust.
Any time the winer is :
LRemoveDust_YV12(17,1)
LimitedSharpen()
01-26-2006, 06:34 AM
-kwag
have used lremovedust() before but need to take a look at limitedsharpen.
01-26-2006, 07:25 AM
Better yet, check out LimitedSharpenFaster..and SeeSaw. Both are discussed thoroughly at the doom9 forums.
01-26-2006, 08:09 AM
Can you copy the code of the function or the link towards the thread please ? There is so much to reach about LS on doom9...
Thanks.
01-26-2006, 09:18 AM
Download the latest MaskTools 2.0 alpha : http://manao4.free.fr/
The function is included in the package, Manao included mg262's functions in MaskTools so there's no need to get the LimitedSupport.dll anymore.
Don't forget to apply Soothe:
http://forum.doom9.org/showthread.php?t=99679
function Soothe(clip sharp, clip orig, int "keep")
keep = default(keep, 24)
keep = (keep>100) ? 100 : (keep<0) ? 0 : keep
KP = string(keep)
diff = yv12lutxy(orig,sharp,"x y - 128 +", U=1,V=1)
diff2 = diff.temporalsoften(1,255,255,32,2)
diff3 = yv12lutxy(diff,diff2, "x 128 - y 128 - * 0 < x 128 - 100 / " + KP
\ + " * 128 + x 128 - abs y 128 - abs > x " + KP
\ + " * y 100 " + KP + " - * + 100 / x ? ?", U=1,V=1)
return( yv12lutxy(orig,diff3,"x y 128 - -",U=2,V=2) )
This version might work with MaskTools 2.0 alpha, better check it before using though as Manao changed some syntax a while ago:
KP = string(keep)
diff = mt_lutxy(orig,sharp,"x y - 128 +", U=1,V=1)
diff3 = mt_lutxy(diff,diff2, "x 128 - y 128 - * 0 < x 128 - 100 / " + KP
return( mt_lutxy(orig,diff3,"x y 128 - -",U=2,V=2) )
SeeSaw is discussed here: http://forum.doom9.org/showthread.php?t=104701
http://home.arcor.de/dhanselmann/_st...2006.01.02.rar (I don't know if it's the latest version so check Didée's online directory to make sure)
01-26-2006, 10:39 AM
Thank you, I will give a look to that
11-06-2006, 07:55 AM
where can I download these filters?
LimitedSharpen()
11-06-2006, 08:28 AM
LimitedSharpen()
These are functions (using several filters). If you wish you can load the whole content of my plugin directory in the link below. You will find these functions in the file calld "function.avsi" and the needed dll are also in the rar.
http://perso.wanadoo.fr/dialhot/Avis...ll_Plugins.rar
11-18-2006, 07:19 AM
why is it after installing the filters from your zip file Dialhot.. the wmp says "computer is running low on memory" when I play the avs file? I have like 100 gigs left in my c drive free.
11-18-2006, 10:56 AM
But maybe you dont have 100 Gigs left as phisical RAM!
11-21-2006, 12:28 PM
12-02-2006, 07:32 AM
OMG!!!
__________________
Rui
All times are GMT -5. The time now is 07:19 PM — vBulletin © Jelsoft Enterprises Ltd
