02-24-2006, 10:17 PM
http://home.arcor.de/the.incredible/pulldown.html
So If I have a 25,0000 or 29,9700 or 60,0000 FPS movie should I always use:
changeFPS(23.976)
or
AssumeFPS(23.976)
Or it is a very bad idea ? If it is a good idea are there better ways than these commands above ?
ps: I think there will be dropped frames this way...
Site Staff / Ad Manager
02-25-2006, 12:38 AM
Hi,
It depends on what you standalone can do: mine for example, even if I am in a PAL zone, can read NTSC format, so I almost never convert the movies from NTSC to PAL (I don't have a lot, but zone 1 DVD are always a headache).
And the conversion may vary, according to the 'gap' you have: from 25 to 23.976, the jump is not high so you can slow the movie a bit (assumefps). But converting from 29,976 to 25 is another story.
The 2 command you mentions can 'convert' from one framerate to another, but in different ways: assumefps speeds up or slows the movies, to keep the frame number but not the duration, and convertfps just keep the duration by dropping or duplicating frames.
Salu2
Fabrice
02-25-2006, 10:01 AM
@fabrice
thanks
The questions is, you can always pulldown:
23.976 -> 25 (PAL)
23.976 -> 29.970 (NTSC)
that is what incredible is saying on his site
The problem is that a I have a lot of 60.0000 fps video of games ( http://bisqwit.iki.fi/nesvideos/) and encoding every @60.0000 fps will take longer than encoding @23.976
Correct me if need so
best regards \o\
02-25-2006, 04:04 PM
CONVERTTOYUY2()
CONVERTFPS(23.976)
CONVERTTOYV12()
I am doing some tests. Currently, I am trying this script above
02-26-2006, 05:53 AM
No need to do this double conversion.
The ChangeFPS can be done at the very end of the script, that means that you can have juste a ConvertToYUY2() then the ChangeFPS() as last lines.
02-27-2006, 01:41 AM
23.976 -> 25 (PAL)
I've never used the pulldown, so I'm not sure I should answer!
If I remember correctly, the pulldown is just a flag that tell the SAP to decode the stream with another framerate. In this case, the effect is the same as convertfps.
Can someone confirm that?
Correct framerates are 23,976, 25 and 29,97, so 60 would give you an error!
CU,
Fabrice
02-27-2006, 02:20 AM
I can
-kwag
02-27-2006, 06:22 AM
Nope
Convertfps does MIX fields to result in a smooth playback so "blendings" will be the result.
What your SAP does when recognising a pulldown flag is this (in avisynth words):
AVISource("24fpsFilm.avi")
SelectEvery(2,0,0,0,1,1).SeparateFields().SelectEv ery(4,1,2).Weave()
So theres no field blending but reordering! Thats why you can InVerseTeleCine this type of stream again without resulting in blendings.
If you have 23.976, then set a pulldown in TmpgEnc before encoding or ad a Pulldown via Pulldown.exe after the encoding in for example CCE etc.
You also can use Dgrafts Pulldown to do a 23.976 to 25 fps pulldown.
02-27-2006, 06:55 AM
BTW I tried this once (to do 23.976 -> 29.970), and it does not work. The MPEG is still analysed as 23.976 by all application I use to open it (DGIndex and DVDLab). Is taht normal ?
02-27-2006, 08:24 AM
changeFPS(23.976)
or
AssumeFPS(23.976)
Good or Bad ? In other words.. if it is 29.970 I must encode @29.970
You mean this? :
SeparateFields
SelectOdd
02-27-2006, 10:11 AM
If you have a progressive source (i.e. you can either use force film or IVTC to get the progressive frames out of the 29.97fps clip), you encode it as progressive at 23.976fps and do the pulldown from 23.976 to 29.97fps.
If you have an interlaced source, you encode as interlaced at 29.97fps.
With game videos it's different. You might get away with SelectEven or SelectOdd and then slowing down to 29.97fps.
02-28-2006, 01:34 AM
Have any1 tested FDecimate() ?
http://neuron2.net/fdecimate/fdecimate.html
LOADPLUGIN("D:\filters\fdecimate101\FDecimate.dll")
AviSource("D:\video\video.avi")
RESAMPLEAUDIO(48000)
CONVERTAUDIOTO16BIT
FDECIMATE()
FDecimate() is an advance over the internal filter ChangeFPS() because it can preferentially deliver unique frames, avoiding duplicates where possible.
02-28-2006, 09:05 AM
Imho the mpeg2 itself is still 23.976 and so it will be recognised. Do a test and play it back on your SAP if it works then only the SAP will recognise the flag.
I remember on a MAC and its videoapps pulldowned NTSC Films will still be recognised as 23.976 by the common softwares used.
02-28-2006, 09:28 AM
The problems is that as DVDLab does not recognize it, I can't author my DVD ! Finally I used DoPulldown "et voilą".
02-28-2006, 04:52 PM
Ive to admit that till now I never used DGpulldown. The 23.976's I did encode where flagged using pulldown.exe (after CCE'ing) or internally switched in TmpGenc. And as my SAP plays them back fawlessly I never needed to convert 23.976's to PAL.
EDIT: Did you just DgPulldown'ed your 23.976 still NTSC px resolution movies or did you also resize them to PAL specs?
02-28-2006, 05:13 PM
Actually, I saw after having encoded 8 NTSC video in 352x480 with CCE that I had forgotted to set the pulldown in the ecl. Logically there were all refused by DVDLab. Then I tried to use DGPulldown to that flag with no success.
All times are GMT -5. The time now is 01:07 PM — vBulletin © Jelsoft Enterprises Ltd
