03-14-2006, 07:09 PM
heres my dvdreasylog
Begin of DVDREasy Conversion Process . . .
Process Started at : 2006/03/13 23:56:21
Free disk Space : 14,893,188 Kb
Computer State . . .
Total Running Processes : 37
.....System Idle Process - 20 K
.....System - 52 K
.....smss.exe - 48 K
.....csrss.exe - 2,756 K
.....winlogon.exe - 3,364 K
.....services.exe - 1,844 K
.....lsass.exe - 1,484 K
.....svchost.exe - 1,740 K
.....svchost.exe - 9,784 K
.....svchost.exe - 1,100 K
.....svchost.exe - 496 K
.....SDMCP.exe - 544 K
.....spoolsv.exe - 1,044 K
.....explorer.exe - 11,460 K
.....PERSFW.exe - 652 K
.....StarWindService.exe - 48 K
.....svchost.exe - 1,836 K
.....wdfmgr.exe - 48 K
.....Fast.exe - 48 K
.....Fast.exe - 176 K
.....point32.exe - 1,328 K
.....type32.exe - 416 K
.....CTHELPER.EXE - 372 K
.....gnotify.exe - 3,496 K
.....iTunesHelper.exe - 168 K
.....qttask.exe - 1,172 K
.....WatchDog.exe - 52 K
.....daemon.exe - 176 K
.....AnyDVD.exe - 524 K
.....jusched.exe - 52 K
.....msnmsgr.exe - 9,100 K
.....TaskSwitchXP.exe - 200 K
.....trillian.exe - 12,012 K
.....iPodService.exe - 760 K
.....btdownloadgui.exe - 96 K
.....dvdreasy.exe - 13,360 K
.....wmiprvse.exe - 4,268 K
DVDREasy settings . . .
[Folders]
Working=F:\working
[Paths]
cce=C:\Program Files\Cinema Craft Encoder SP v2.67.00.27\cctsp.exe
[CCE]
vbr_pass=3
quality_prec=17
use_filter=0
filter_val=2
gop_m=3
gop_nm=4
seq_hdr=1
all_closed_gop=0
fix_gop_length=0
progressive=0
alternate_scan=0
non_linear=0
dvd=0
intra_dc_prec=-1
vmode=multipass
default_script=1
[ISO BURN]
dvdrw_drive_letter=
delete_files=0
[ENCODER]
name=hc
[HC]
profile=Best
dc_prec=Auto
noseq_endcode=0
closedgops=0
matrix=NOTCH
vmode=multipass
default_script=1
Choosed settings information
IFO File : H:\VIDEO_TS\VTS_08_0.IFO
Type : MPEG2 720x480
Aspect : NTSC 16:9 letbox
Lenght : 01:29:03
Chapters : 30
Primary Audio : 0x80, English - AC3 6Ch
Secondary Audio : --- No Audio ---
Primary Subtitles : --- No Subtitles ---
Secondary Subtitles : --- No Subtitles ---
Create Iso Image : True
ISO Volume Label : ZOOLANDER
Burn Iso Image : False
STEP - Executing DVD Decrypter to rip VOB files . . .
Step Started at : 2006/03/13 23:56:22
Command line : cmd /c cd "F:\working" && "C:\Program Files\DVD Decrypter\dvddecrypter.exe" /MODE IFO /SRC H: /DEST "F:\working" /VTS 08 /PGC 1 /ANGLE 1 /DIRECT 0xE0 0x80 /START /CLOSE
Step ended at : 2006/03/14 00:06:24
Free disk Space : 10,285,944 Kb
STEP - Analising ripped VOB files . . .
Ripped VOB Files Size : 4,607,240 Kb
Re-encoding needed : True
STEP - Creating DGINDEX project & Demuxing audio track(s) . . .
Step Started at : 2006/03/14 00:06:24
Command line : cmd /c "C:\Program Files\DVDREasy\dgmpegdec\dgindex.exe" -CS=2 -TN=1 -OM=2 -AIF=[F:\working\vts_01_1.vob] -OF=[F:\working\movie] -exit
Step ended at : 2006/03/14 00:09:18
Free disk Space : 9,992,796 Kb
STEP - Bitrate calculation
Audio Bitrate (Kbps) : 448
New Video Bitrate (Kbps) : 6386
STEP - Creating AVS File . . .
LoadPlugin("C:\Program Files\DVDREasy\dgmpegdec\DGDecode.dll")
mpeg2source("F:\working\movie.d2v")
AddAudio()
ConvertToYV12()
STEP - Executing MPEGinfo to get video settings . . .
Step Started at : 2006/03/14 00:09:18
2638 horizontal size
921 vertical size
12 aspect ratio (1=1:1, 2=4:3, 3=16:9, 4=2.21:1)
11 framerate (3=25, 4=29.97)
4089200 nominal bitrate
227 VBV buffer size
1 chroma (1=4:2:0, 2=4:2:2, 3=4:4:4)
10 DC precision
3 picture structure (1,2=field, 3=frame)
0 top field first (0=no, 1=yes)
0 DCT type (0=field, 1=frame)
0 scan method (0=zigzag, 1=alternate)
1 frame type (0=interlaced, 1=progressive)
0 Q scale (0=linear, 1=nonlinear)
PullDown needed : True
Step ended at : 2006/03/14 00:09:26
STEP - Creating HC.INI File . . .
*ASPECT 16:9
*BITRATE 6386
*MAXBITRATE 9100
*INFILE F:\working\movie.avs
*LOGFILE F:\working\hc.log
*OUTFILE F:\working\movie.mpv
*MATRIX NOTCH
*PROFILE Best
*DC_PREC 10
*INTERLACED
STEP - Executing HC ENCODER to Encode Video . . .
Step Started at : 2006/03/14 00:09:26
Command line : cmd /c cd "F:\working" && "F:\working\hcbatch.exe" -ini "F:\working\hc.ini"
Step ended at : 2006/03/14 03:16:25
Free disk Space : 5,825,232 Kb
STEP - Executing PULLDOWN . . .
Step Started at : 2006/03/14 03:16:25
Command Line : cmd /c cd "F:\working" && "C:\Program Files\DVDREasy\pulldown\pulldown.exe" F:movie.m2v F:final.m2v
Step ended at : 2006/03/14 03:26:04
Free disk Space : 5,825,812 Kb
Executing Muxman to Author New DVD . . .
Step Started at : 2006/03/14 03:26:05
Command line : cmd /c start /w /HIGH /d"C:\Program Files\DVDREasy\muxdemux" muxman "F:\working\movie.mxp" -d "F:\working\video_ts" -l "F:\working\muxman.log" -run
Step ended at : 2006/03/14 03:26:09
Free disk Space : 9,992,780 Kb
muxman log
MuxMan version 0.13h
Opened script file F:\working\movie.mxp
Rejected, unknown file type F:\working\movie.m2v
Accepted audio F:\working\movie T01 3_2ch 448Kbps DELAY 22ms.ac3
expanded database to 116 entries.
expanded database to 132 entries.
expanded database to 148 entries.
expanded database to 164 entries.
expanded database to 180 entries.
No video file declared
when i goto the working directory
i have movie.avs movie.d2v and movie.mxp
no movie.m2v file
Site Staff / Ad Manager
03-14-2006, 07:22 PM
Hi Azeworai,
Just one thing, Do you have FINAL.M2V file ?
03-14-2006, 07:34 PM
@dvdreasy
Nope:/
03-14-2006, 08:05 PM
Movie.m2v has been removed after the failed muxman operation (look at the free disk space before and after).
The things to understand is :
03-15-2006, 06:46 AM
Yes I saw that, but the question is why muxman DELETE the M2V file ???
@Azeworai
This only happened with this movie ? did you tried DVDREasy conversion with other movies ?
03-15-2006, 02:20 PM
@dvdreasy
Checking right now with another movie
when finished i will post results
03-15-2006, 10:13 PM
used Constantine as movie
@dvdreasy
Everything worked fine
Process Started at : 2006/03/15 16:16:08
Free disk Space : 20,302,600 Kb
Total Running Processes : 40
.....System - 56 K
.....smss.exe - 76 K
.....csrss.exe - 1,840 K
.....winlogon.exe - 2,808 K
.....services.exe - 1,804 K
.....lsass.exe - 1,544 K
.....svchost.exe - 1,648 K
.....svchost.exe - 7,728 K
.....svchost.exe - 816 K
.....svchost.exe - 548 K
.....SDMCP.exe - 624 K
.....explorer.exe - 17,520 K
.....spoolsv.exe - 960 K
.....PERSFW.exe - 644 K
.....svchost.exe - 1,812 K
.....wdfmgr.exe - 80 K
.....Fast.exe - 64 K
.....Fast.exe - 192 K
.....point32.exe - 1,240 K
.....type32.exe - 284 K
.....CTHELPER.EXE - 360 K
.....gnotify.exe - 2,144 K
.....iTunesHelper.exe - 180 K
.....qttask.exe - 176 K
.....WatchDog.exe - 72 K
.....daemon.exe - 196 K
.....AnyDVD.exe - 560 K
.....jusched.exe - 80 K
.....pg2.exe - 888 K
.....TaskSwitchXP.exe - 232 K
.....NMBgMonitor.exe - 2,636 K
.....ObjectDock.exe - 8,444 K
.....iPodService.exe - 772 K
.....btdownloadgui.exe - 5,280 K
.....trillian.exe - 5,152 K
.....firefox.exe - 38,776 K
.....btdownloadgui.exe - 44,244 K
.....dvdreasy.exe - 12,948 K
.....wmiprvse.exe - 4,308 K
[Folders]
Working=F:\working
[Paths]
[CCE]
vbr_pass=3
quality_prec=17
use_filter=0
filter_val=2
gop_m=3
gop_nm=4
seq_hdr=1
all_closed_gop=0
fix_gop_length=0
progressive=0
alternate_scan=0
non_linear=0
dvd=0
intra_dc_prec=-1
vmode=multipass
default_script=1
[ISO BURN]
dvdrw_drive_letter=
delete_files=0
[ENCODER]
name=hc
[HC]
profile=Best
dc_prec=Auto
noseq_endcode=0
closedgops=0
matrix=NOTCH
vmode=multipass
default_script=1
IFO File : H:\VIDEO_TS\VTS_02_0.IFO
Lenght : 02:00:39
Chapters : 34
Primary Subtitles : 0x20, English
ISO Volume Label : CONSTANTINE
Step Started at : 2006/03/15 16:16:10
Command line : cmd /c cd "F:\working" && "C:\Program Files\DVD Decrypter\dvddecrypter.exe" /MODE IFO /SRC H: /DEST "F:\working" /VTS 02 /PGC 1 /ANGLE 1 /DIRECT 0xE0 0x80 0x20 /START /CLOSE
Step ended at : 2006/03/15 16:27:51
Free disk Space : 14,910,552 Kb
Ripped VOB Files Size : 5,358,524 Kb
Step Started at : 2006/03/15 16:27:52
Step ended at : 2006/03/15 16:31:23
Free disk Space : 14,513,396 Kb
New Video Bitrate (Kbps) : 4596
STEP - Executing VobSub to extract subtitles . . .
Step Started at : 2006/03/15 16:31:23
Command Line : cmd /c rundll32 "C:\Program Files\DVDREasy\subtitles\vobsub.dll",Configure F:\working\vobsub.txt
Step ended at : 2006/03/15 16:34:32
Free disk Space : 14,485,336 Kb
STEP - Executing SUBTOSUP to converte subtitles . . .
Step Started at : 2006/03/15 16:34:33
Step ended at : 2006/03/15 16:34:36
Free disk Space : 14,483,972 Kb
AddAudio()
ConvertToYV12()
Step Started at : 2006/03/15 16:34:36
720 horizontal size
480 vertical size
3 aspect ratio (1=1:1, 2=4:3, 3=16:9, 4=2.21:1)
4 framerate (3=25, 4=29.97)
7500000 nominal bitrate
112 VBV buffer size
10 DC precision
1 DCT type (0=field, 1=frame)
1 Q scale (0=linear, 1=nonlinear)
PullDown needed : False
Step ended at : 2006/03/15 16:34:45
*ASPECT 16:9
*BITRATE 4596
*MAXBITRATE 9100
*MATRIX NOTCH
*PROFILE Best
*DC_PREC 10
Step Started at : 2006/03/15 16:34:46
Step ended at : 2006/03/15 20:39:20
Free disk Space : 9,641,764 Kb
Step Started at : 2006/03/15 20:39:21
Step ended at : 2006/03/15 20:54:32
Free disk Space : 5,049,748 Kb
STEP - Creating ISO Image . . .
Step Started at : 2006/03/15 20:54:37
Command Line : "C:\Program Files\DVDREasy\iso\mkisofs.exe" -dvd-video -V "CONSTANTINE" -o "F:\working\ISO\movie.iso" "F:\working\dvd\"
Step ended at : 2006/03/15 21:05:31
Free disk Space : 1,697,252 Kb
End of DVDREasy Conversion Process . . .
Process Ended at : 2006/03/15 21:05:31
All times are GMT -5. The time now is 04:24 PM — vBulletin © Jelsoft Enterprises Ltd
