Quantcast What Tools to Make a KVCD in PAL Format? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Video Encoding and Conversion
04-21-2007, 04:37 AM
lucozade lucozade is offline
I have made kvcd before using acp but have been told to use tmpgenc as this is alot better.
Is there a updated guide to what tools i would need to make a kvcd in pal format. The tools i have so far are.
Tmpgenc Plus 2.521.58.169
K Lite Codec Pack 2.89 Full
CQMatic
GSpot
Site Staff / Ad Manager
04-21-2007, 04:41 AM
Dialhot Dialhot is offline
And at which step are you stuck ?
You can start with Black Prince's guide :
http://www.kvcd.net/forum/viewtopic.php?t=2885
(just use dgindex insteed of dvd2avi, as it is its successor).
04-21-2007, 05:42 AM
Sorry but i think i should have asked this in the avi forum as i want to make a kvcd from a avi. I need to no what tools i would need or would the tools i got now be any good.
04-21-2007, 06:09 AM
I guess that this is not a capture either. There are a lot of guides in the avi -> kvcd section, you can peak up the one you want. There is nothing really new in that domain.
Tou don't need other things than CQMatic, tmpgenc and avisynth. The versions you have are good enought.
Webpage Tools black prince Computers 0 04-07-2006 07:46 AM
how to make any format of film fit onto a CD-R and play on my DVD player? Frosty Video Encoding and Conversion 8 02-23-2006 04:46 PM
Ebay Sellers Tools black prince Computers 0 12-22-2004 07:56 AM
Audio tools matto Video Konvertierung und Encodieren (Deutsch) 2 10-25-2003 08:01 AM
Can Kvcd be mounted on Daemon tools? choogler23 Video Encoding and Conversion 1 07-15-2003 01:47 AM
All times are GMT -5. The time now is 02:34 AM  —  vBulletin © Jelsoft Enterprises Ltd
