Quantcast Avisynth: Help with Double-Hard Telecine ? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Avisynth Scripting
08-20-2008, 01:46 PM
tengo6dedos tengo6dedos is offline
hello
I have this source and i think is double hard telecine but im not sure, i tried forcing with dgindex then i tried a simple:
Telecide()
Decimate()
but sill got some interlaced frames, i also read that anime is a bit difficult to treat when having this issue so im better askin
here is a sample
http://www.mediafire.com/download.php?40x4nkeq15y
thanks a lot for your help
Site Staff / Ad Manager
08-21-2008, 01:00 PM
Dialhot Dialhot is offline
I first tried this :
DGDecode_Mpeg2Source("D:\Mes KVCD\atado.d2v")
tfm()
tdecimate(mode=1,hybrid=1)
That gives good results (no more combed frames), but according to the TIVTC documentation (where tmf and tdecimate functions are implemented), the correct qay to deal with an anime should be :
tfm(d2v="D:\Mes KVCD\atado.d2v")
Unfortunately this one give me an error, as tfm does not understand the d2v. So I looked for a more recent version of the plugin and I found this on doom9 :
AnimeIVTC() - No more blends, jerky movement, residual combing nor jagged edges!
This script should solve all your issues.
Note: è divertendo intendere un japanime in italiano
08-21-2008, 04:45 PM
thanks, ill try tfm() which plugin is that?
I also found AnimeIVTC before asking but when doin this:
AnimeIVTC(mode=2,aa=3,killbomc=2)
..plus some filtering gave me 0.3 fps
in the AnimeIVTC guide the guy says he recomend to do a lossless rendering pass with this function alone because is very slow, but i dont think is gettin any better in my w.c. computer
finally since we here ..what kind of filterin aiming for compression would you use in this one?
thanks
saluts
08-21-2008, 06:31 PM
As I said, the plugin is TIVTC and you will find it on doom9 too (or you can find my avisynth dir as usual here :
www.kvcd.net/downloads/Avisynth_All_Plugins.rar
But as I said, my version is old.
I don't do a lot of anime but some classic cartoons like Disney, I generally use Dup() on them.
Dup(Threshold=3,maxcopies=3,blend=false)
08-29-2008, 01:30 PM
yes, dup helps removing duplicates but i fear that audio sync may go off, is that correct?
08-29-2008, 04:12 PM
It does not remove duplicates, it replace row of image that are very close by several intances of the same frame. This way the compression is better.
09-02-2008, 12:04 PM
thanks for the info!
Fixing bad telecine job? J-Wo Video Encoding and Conversion 11 07-19-2004 07:57 AM
Fields to Frames and Telecine with AVISynth? The Alvinator Avisynth Scripting 26 12-13-2003 11:02 AM
Avisynth: Double converson for better quality? MrTibs Avisynth Scripting 9 10-29-2003 04:32 PM
DVD2AVI: Double speed playback Yoda Video Encoding and Conversion 9 01-22-2003 05:41 PM
KVCD: Which template to use? how to double Frameserve? Bigswaffo Video Encoding and Conversion 2 12-07-2002 04:58 PM
All times are GMT -5. The time now is 07:20 AM  —  vBulletin © Jelsoft Enterprises Ltd
