Quantcast Best Capture Resolution for VCDs? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Video Capturing / Recording
10-31-2002, 02:28 AM
holgerschlegel holgerschlegel is offline
Hi,
If I want to capture and encode a movie (from tv) as kvcd-352x288 (because my dvd player doesn't like the other kwag mpeg-1 templates), what is the way to get the best results (quality and size)?
a) capture at target resolution (352x28 and so dropping one field of each frame
b) capture both fields (352x576) and (bilinear-)resize to target resolution
Regardless of capture resolution I'll resize via FitCD generated script to crop of black borders (and add them again) and to add a tv-block-overscan of 1.
Thx
Holger
Site Staff / Ad Manager
10-31-2002, 05:03 AM
andybno1 andybno1 is offline
Send a message via MSN to andybno1 Send a message via Yahoo to andybno1
well I would suggest capturing at a high resolution and then run the the capture file through either fitcd or staight to tempgenc. I'm doing something similar, I am capturing these half an hour short films of a comedy channel and then running it through real producer plus 8 to save on space, I captured t 640 X 480 and used a m-jpeg codec which I got last nite of a friend.
11-02-2002, 06:39 PM
Usually I capture at 352x576 (using picvideo mjpeg codec at q19) and then resize (via FitCD created avs script) to the target resolution of 352x288. Question: Can a highter x resolution at capture increase the quallity or does that only increase the disk space needed for capture?
Thx.
Holger
11-02-2002, 07:07 PM
kwag kwag is offline
Hi holgerschlegel,
I don't think you'll see more quality gain capturing above 352x576, if your target is 352x288. You're already capturing both fields, which is good, but increasing the horizontal capture resolution above 352 won't do much.
-kwag
11-06-2002, 10:47 AM
Boulder Boulder is offline
If you have a noisy source (and plan to do some noise reduction), you should capture at a higher horizontal resolution. Resizing will remove some of the noise in the capture.
should avi capture have resolution equal to output video? radunn Video Encoding and Conversion 10 02-20-2004 06:45 PM
VirtualDub: Will only capture at 720x288 resolution? andybno1 Video Encoding and Conversion 7 12-01-2003 05:56 PM
what reslution should I capture video in for VCDs? cbr900 Video Capturing / Recording 1 09-06-2002 08:41 AM
Recording Video: what resolution do I capture in? cowman Video Capturing / Recording 1 08-04-2002 10:52 PM
What capture resolution for 352x240 template? rendalunit Video Capturing / Recording 6 06-18-2002 08:58 AM
All times are GMT -5. The time now is 11:01 PM  —  vBulletin © Jelsoft Enterprises Ltd
