Quantcast KVCD: Subtitles Out of Sync? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Subtitles
03-07-2003, 05:11 PM
Wolfi Wolfi is offline
Send a message via AIM to Wolfi Send a message via MSN to Wolfi Send a message via Yahoo to Wolfi
When I play my subtitle with the source witch is avi. it plays correctly,the sub is in sync.. But when I played the movie with subtitle as an avs. file it was out of sync I've tried everything with no succsess Is it anyway to fix this problem in an easy way Or just I good guide I can follow
//Wolfi
Site Staff / Ad Manager
03-07-2003, 07:28 PM
KingTuk KingTuk is offline
did you try frameserving with virtualdub?
03-08-2003, 09:46 AM
PyRoMaNiA PyRoMaNiA is offline
have you actually tried encoding the AVS file? When I play AVS files with WMP I often get lots of sync problems, skipping, etc. But the encoded file is usually fine. Try encoding a sample to check it's OK.
03-08-2003, 10:10 AM
CheronAph CheronAph is offline
Send a message via MSN to CheronAph
Have you checked that the video and the subs are with same frame rate?
03-08-2003, 10:24 AM
Yes I've tried to encode one of the avs. scripts, and yes the result was waaay out of sync (the sub), and yes the video and the sub are in the same frame rate
But I havent tried to frameserve with virtualdub. Is there any good "frame serving" guide out there? cause I havent frame served in my life
Thanks for anwering
//Wolfi
03-08-2003, 10:53 AM
first before you run virtualdub make sure you run auxsetup and install the frameserver...
The way I use virtualdub is to load the avi and add the filters including the resize. It comes with a few filters but you will probably want to download some that are for virtualdub, similar to what you use in avisynth and copy them into the plugins folder and one of those being texsub.vdf that comes with vobsub for your subtitles. It's pretty easy since there is no scripting involved. Once you have your movie the way you want it then you click on start frame server from the file menu. Then open the file that it created with tmpgenc to start encoding...
That's basically it...
03-08-2003, 11:00 AM
Well, can i open the avs. file instead of the avi. file ? It's no problem when i play the sub with my avi. file it's when I play the avs. file the sub is out of sync. So it's the avs. file I need to frameserve
Thank you
//Wolfi
03-08-2003, 11:28 AM
I don't use virtualdub that much, but you can also have virtualdub open an avs file without the subtitle stuff in the script and then add the subtitle with virtualdub as the only filter then frame serve ( don't resize or anything else since you already did that in your avs script )...
I would try the first option I gave you before this option...
03-08-2003, 01:40 PM
Oke KingTuk I'll try
06-12-2004, 09:22 PM
WOWIEGURL WOWIEGURL is offline
Send a message via ICQ to WOWIEGURL
I can't find this textsub.vdf, I cann only find textsub.txt in the VObSub folder. Vsfilter lets me include subs in the movie when I play the avs in wmp, but when I use TextSub it doesn't like it. What can I do? I prefer to use TEXTSUB
06-12-2004, 09:29 PM
rds_correia rds_correia is offline
Wowie,
It's not a question of prefering or not.
Either your subs file is text based or not!
If it is text based you used TextSub, if not you use VobSub as I already explained.
From the type of files you described me you have, I must assume they are not text based.
In such sense you need to use VobSub.
Try to maintain your questions in the same forum when related to the same subject/issue.
Cheers
__________________
Rui
KVCD subtitles hidden? Blubear Subtitles 3 07-16-2004 01:47 PM
Subtitles: Adding .srt subtitles to a KVCD movie xpronic Subtitles 13 06-12-2004 09:33 PM
VobSub subtitles displayed too early, out of sync audioslave Subtitles 5 06-16-2003 05:56 PM
KVCD: How to add subtitles? Evangelion-01 Video Encoding and Conversion 1 06-05-2003 04:05 PM
KVCD: Subtitles not In Sync? gerrycurl21 Subtitles 9 04-20-2003 02:04 PM
All times are GMT -5. The time now is 02:20 AM  —  vBulletin © Jelsoft Enterprises Ltd
