Quantcast KVCD Subtitles All messed up? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Subtitles
04-18-2003, 02:24 PM
andybno1 andybno1 is offline
Send a message via MSN to andybno1 Send a message via Yahoo to andybno1
anyone suggest best way to get lotr extended edition from 2 dvds to one cd with the elfish subs?? I tried last night rippin all vobs to had drive and renamin second disc vobs to use with one ifo file, I used dvd2svcd to rip the subs but when it came to selectin the subs, they where all messed up. Any suggestions would be appreciated.
Site Staff / Ad Manager
04-19-2003, 12:51 AM
urban tec urban tec is offline
Nothin like pushin the limits...
Two ways I know to do this
1: use ifoedit and vobedit to join the vobs see here for guide etc
2: do both dvd seperately and join resulting mpegs or maybe use 2 mpeg2 sources in your avs script (not sure if you can do this but I think so)
either way you are going to need to do some learnin to get it to work.
04-19-2003, 04:13 AM
cheers I will give it a go and hoepfully I will be able to do it.
04-19-2003, 07:05 AM
PyRoMaNiA PyRoMaNiA is offline
In case you decide to use 2 MPEG2Sources, try this:
a=MPEG2Source("C:\...\file1.d2v")
b=MPEG2Source("C:\...\file2.d2v")
x=a+b
x
04-19-2003, 01:18 PM
black prince black prince is offline
@andybno1,
Another possible way is to add each VOB using DVD2AVI v 1.76 from
each set and create the .d2v as usual. The hard part is getting this
onto 1 CD with some kind of quality. If I had to do this, I would use
DVDShrink to remove any audio other than English, End credits, and
maybe Intro credits. Save this as a VOB structure and then use DVD2AVI
to create .d2v. But even with all that work, I don't believe it will look
that good.
-black prince
Anway way to fix a messed up Mpeg video and audio? NittoLive Video Encoding and Conversion 3 04-22-2006 05:39 PM
Subtitles: Adding .srt subtitles to a KVCD movie xpronic Subtitles 13 06-12-2004 09:33 PM
DVD decrypting - video is messed up? Dmaster87 Video Encoding and Conversion 1 01-13-2004 06:31 AM
KVCD: Does audio sync get messed up if you convert 30fps to 24fps? audi2honda Video Encoding and Conversion 0 06-27-2003 10:53 PM
Encoding: Messed-up color with divx rendalunit Video Encoding and Conversion 6 01-14-2003 07:30 PM
All times are GMT -5. The time now is 12:20 AM  —  vBulletin © Jelsoft Enterprises Ltd
