Quantcast Besweet: How to Merge Two WAV Files? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Audio Conversion
10-22-2003, 03:31 PM
Zyphon Zyphon is offline
Hi I have a DivX movie which is a 2CD for better quality and i used Virtual Dub to save the VBR audio to WAV.
Now i have 2 WAV files that i need to merge into one as i use ToK to convert my DivX to KVCD.
Merging the AVI is easy as i use the AVS Script AviSource ++ AviSource.
Can BeSweet merge the 2 wavs or do i need to do it with another audio encoder or indeed can Windows merge by way of a command line?
Thanks in advance for any help given.
__________________
Regards.
Michael.
Site Staff / Ad Manager
10-22-2003, 03:43 PM
jorel jorel is offline
don't know if BeSweet do it...maybe yes but i don't know how!
you don't have any wave editor like cool edit,sound forge...?
tons of options!
your audio board don't came with an wave editor?
10-22-2003, 04:08 PM
Dialhot Dialhot is offline
Open the fist Divx in Vdub, then the second one by selecting "Append AVI segment" in file menu of Vdub. Then extract the audio in wav as always : you will have a joined wav file
10-22-2003, 04:43 PM
Thanx 4 the tips guys if the VDub method doesnt work ill try Cool Edit i have that somewhere around here.
Thanks again guys.
__________________
Regards.
Michael.
Subtitles: MERGE two SETS OF .SRT FILES? WOWIEGURL Subtitles 13 07-08-2005 05:39 PM
BeSweet: Various setting in besweet - normalize, downmix? zagor Audio Conversion 1 06-14-2004 04:11 PM
BeSweet: Join two audio files by Besweet? dongxu Audio Conversion 2 04-02-2004 03:15 AM
BeSweet: Besweet crashes when trying to convert OGG files rs008f Audio Conversion 29 03-04-2004 02:54 PM
KVCD steps - Can i merge the avi files to one big one? neosmatrix Video Encoding and Conversion 1 05-07-2002 11:30 AM
All times are GMT -5. The time now is 10:59 PM  —  vBulletin © Jelsoft Enterprises Ltd
