Quantcast Made a KDVD! How to Burn it ? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Authoring VCD, DVD, Blu-ray
12-04-2003, 10:43 AM
The Neta The Neta is offline
you see..
i made an Kdvd with TMPGEnc i dont have an dvd-r burner and i split the big mpeg file to 2 files. now.. how to burn it ?
i got nero i try it on vcd and it doesnt work on my dvd, my dvd recornize it as vcd2 and i still see a black scerrn with no sound .. so how to born ?
please help...
Site Staff / Ad Manager
12-04-2003, 10:52 AM
please.. help..
12-04-2003, 11:14 AM
Boulder Boulder is offline
No one answered in 10 minutes and you start bumping your post?
PATIENCE IS A VIRTUE
Why the heck did you make a KDVD if you don't have a DVD burner?
12-04-2003, 11:17 AM
becuase the quality is much better in kdvd..
and how to burn it ?
12-04-2003, 11:18 AM
Dialhot Dialhot is offline
Buy a DVD burner !
12-04-2003, 11:19 AM
there is must be anouther way...
12-04-2003, 11:25 AM
No it isn't.
I should ask you what exactly you called "KDVD" in order to help you but I won't because of the way you double post in less than 10 min claiming for help.
12-04-2003, 11:27 AM
kwag kwag is offline
Your best bet, if you don't want to re-encode, is to split that mpeg file, and try to burn as SVCD. See if your player will play it.
If you have problems with the audio, demux and re-encode the audio at 44.1Khz.
But if you really want that top KDVD quality, you'll have to but a DVD
Edit: And DON'T bump posts
-kwag
12-04-2003, 11:28 AM
This way he doesn't do a KDVD but a MPEG2 KVCD (perhaps with shroter GOP and 48Khz audio). I do not see where is the better result.
12-04-2003, 11:29 AM
you help me soo much ! thenx admin
12-04-2003, 11:32 AM
I will try it out and i will psot here the resultes..
12-04-2003, 11:33 AM
Well, if he already did a KDVD, which should be DVD quality, then there's no other choice than to split the mpeg to fit it in 2 or 3 CD's
But then, that voids all of our 1 CD principles
-kwag
12-04-2003, 12:20 PM
now its working very well without any audio problams.. thenks !
Made a kdvd with ac3, but wmp won't find a codec? Adder Video Encoding and Conversion 3 10-02-2004 10:44 AM
Made First KDVD - disappointed Uruk-hai Video Encoding and Conversion 8 04-11-2004 08:20 PM
Made my First kdvd with success! zagor Video Encoding and Conversion 4 04-04-2004 09:58 AM
made kvcd .bin file, but what program to burn it with? maurice.lock Video Encoding and Conversion 6 09-16-2003 05:37 PM
Any KDVD GUIDEs made yet? scb212 Video Encoding and Conversion 2 06-30-2003 08:48 PM
All times are GMT -5. The time now is 09:01 PM  —  vBulletin © Jelsoft Enterprises Ltd
