Quantcast How to Add Subtitles (SRT) to an Extracted .DAT File - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Subtitles
12-10-2003, 02:31 PM
Paulus Paulus is offline
I cannot load the .dat file into WinsubMux so I need to convert to .mpg file first. I've tried this with VCD easy's MPEG tool "cdxa2mpg" which is intended for chaning .dat files to .mpg file, but......
I get an errormessage saying that my .dat file (extracted from .bin file with IsoBuster) is not an actual .dat file (with "RIFF" header (??)).
Someone can point me in the right direction ?
Edit: I see that WinSubMux doesn't handel .srt files. How to ad .srt subs to a .mpg file ? (what software ?)
Site Staff / Ad Manager
12-10-2003, 06:21 PM
Hmmmm....no reply yet, that's a pitty....
Well, meanwhile, I converted my .dat file to .mpg with vcdGear....+ I have two versions of subs (.srt + .ssa). It seems that WinSubMux can only make switchable subs and not permanent ones (which I need voor my KVCD).
Please help me as I am doing "Scarface" and I realy want to see the movie with subs (Toni Montana is hard to follow for me ...).
Greets...
12-11-2003, 04:17 AM
Dialhot Dialhot is offline
Paulus, let think a little : adding permanent subs means to add somthething ON THE PICTURE, that is the same to removing something from the picture and that means... hum... ?
Re-encode !
12-11-2003, 02:06 PM
Sorry for my stupidity (seriously).
I have a little experience meanwhile but not so much with manual KVCD procedure (That's what lead me to DVD2SVCD in the first place).
Subs was the problem for me in the very beginning and now again. I haven't been able to find a good guide for subs.
But, I think I can make a new .avs script with note pad using the Textsub command yes ? Something like:
Mpeg2source("D:\Scarface.d2v")
BlindPP(cpu=4)
Blockbuster(method="noise",detail_min=1,detail_max =3,variance=0.1,seed=1)
Convolution3D(1, 6, 12, 6, 8, 2.8, 0)
GripCrop(352,288,overscan=1, source_anamorphic=false)
GripSize(resizer="LanczosResize")
Undot()
TemporalSoften(2,7,7,3,2)
DCTFilter(1,1,1,1,1,1,0.5,0)
GripBorders()
Textsub ("d:\scarface.srt")
Will the quality be affected by the re-encode ?
Is the syntax for "textsub" correct ?
Can I use the .style file for subs and how do I preview the position of the subs ?
Sorry to keep on bugging you...
PS: by the way, my Pinokkio project (2 SVCD discs -> 1 KVCD dis) turned out fantastic ! Thanks for your help on that. I'm getting the hang of it
12-11-2003, 02:49 PM
BlindPP(cpu=4)
Undot()
GripBorders()
That is exactly that.
will the quality be affected by the re-encode ?
For sure
Yes it is.
Textsub automatically use the .style file if it finds one.
12-13-2003, 08:09 AM
Thanks for the advice.
I think I won't go for the subs and leave it like it is....
I don't want to compromise the quality for this project
Can I Remove Subtitles from AVI File? Bombero0437 Video Encoding and Conversion 4 02-04-2005 12:24 PM
way to check and see whether the extracted audio is playing at 25fps? the_ray Video Encoding and Conversion 21 11-25-2003 07:46 AM
Subtitles: What type of file is this? rendalunit Subtitles 0 05-25-2003 03:48 PM
How to use .srt file to embed Subtitles? gonzopdx Subtitles 2 05-15-2003 06:46 PM
DVD2AVI: No ac3 extracted rendalunit Video Encoding and Conversion 1 10-08-2002 05:57 PM
All times are GMT -5. The time now is 01:16 AM  —  vBulletin © Jelsoft Enterprises Ltd
