Quantcast Best Scripts for Pvr250 Captures to 704x480 - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Video Capturing / Recording
12-11-2003, 08:37 AM
nicksteel nicksteel is offline
Kwag,
Have you encoded any PVR250 captures to 704x480, and if so, which script have you used for this?
Site Staff / Ad Manager
12-11-2003, 08:40 AM
kwag kwag is offline
Originally Posted by nicksteel
Kwag,
Hi nicksteel,
No I haven't.
I have only played back the captures (which look awesome!), but I haven't encoded them.
-kwag
12-11-2003, 08:50 AM
Yeah, the captures are very clean. So far, I've just been using the MA script ( with telecide and decimate) as is with the x3 template reset to 704x480. I've put 80 minutes at 60+ CQ on one CD with pretty good results. I use 2 CD's for even better saves. I use VirtualDub-MPEG to cut and DVD2AVI to avoid changing the source. You can either go miniDVD with your Cyberhome or SVCD.
12-16-2003, 10:05 AM
fastbeagle fastbeagle is offline
I haven't bought one yet ....but this link might be usefull http://www.shspvr.com/
Avisynth: STMedianFilter in the Latest Scripts For VHS and captures? dongxu Avisynth Scripting 3 02-26-2004 09:51 AM
DVRs: Software for PVR250/350 rhino Video Capturing / Recording 3 01-08-2004 12:39 PM
DVRs: Audio settings, WinTV2000 and PVR250 nicksteel Video Capturing / Recording 23 12-23-2003 05:29 PM
Must capture audio via your PC soundcard, with PVR250 or PVR350? jamesp Video Capturing / Recording 7 12-20-2003 06:26 AM
KVCD: No Two Captures The Same ? LadyMiles Video Encoding and Conversion 0 10-14-2002 02:09 AM
All times are GMT -5. The time now is 09:39 PM  —  vBulletin © Jelsoft Enterprises Ltd
