Quantcast Must Capture Audio Via Your PC Soundcard, with Pvr250 or Pvr350? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Video Capturing / Recording
12-18-2003, 11:36 AM
jamesp jamesp is offline
I'm in the Market for a new TV Card and I like the look of this card. Can anyone with one tell me if you still need to capture audio via your PC soundcard, or does it have its own audio inputs. Is it good with audio/video sync, even after re-encoding to a KDVD?
Cheers,
Jim
Site Staff / Ad Manager
12-18-2003, 11:41 AM
nicksteel nicksteel is offline
Cheers,
Jim
They are self contained. No connections to sound card. You might want to look at the sound issues that are being discussed now.
12-18-2003, 12:26 PM
Sorry - where are these threads - can't find it.
Cheers,
Jim
12-18-2003, 02:35 PM
Cheers,
Jim
http://www.kvcd.net/forum/viewtopic....025&highlight=
12-19-2003, 05:08 PM
nicksteel - cheers for that. I currently own a Wintv Go. Do you recommend the PVR250? Do your captures look good? My target s Pal DVD.
Jim
12-19-2003, 06:20 PM
Jim
Go for it! My previous card was a WinTVGO90. I like the quality from the PVR250 much better. The captures look like DVD's at 720x480, so will probably look perfect in PAL.
12-20-2003, 06:01 AM
What software do you use to capture - do you use the HAUPPAUGE software or software from a 3rd party?
Jim
12-20-2003, 06:26 AM
I use the software that comes with the board.
Do I Need a Time Base Corrector? (PVR-350 Problem) rab Video Capturing / Recording 10 05-11-2007 09:15 AM
DVRs: Software for PVR250/350 rhino Video Capturing / Recording 3 01-08-2004 12:39 PM
DVRs: Audio settings, WinTV2000 and PVR250 nicksteel Video Capturing / Recording 23 12-23-2003 05:29 PM
Best scripts for PVR250 captures to 704x480 nicksteel Video Capturing / Recording 3 12-16-2003 10:05 AM
Capture audio clickit Audio Conversion 4 09-24-2003 07:56 AM
All times are GMT -5. The time now is 03:04 AM  —  vBulletin © Jelsoft Enterprises Ltd
