04-21-2024, 09:00 PM
Originally Posted by keaton
Shocking that something basic like ChromaShift is not available in modern Avisynth.
It's not the same, but ChromaShiftSP() is x64. I've used it, but it does behave differently. As always, verify everything, before and after processing. It's a fiddly .avsi script, not a .dll filter.
04-22-2024, 12:45 AM
04-22-2024, 08:10 AM
UPDATE. my system is x64 so it doesnt run x32 colorshift dll.. now trying to find x64 version. i hope there is one.
Use the 32 bit original version of Avisynth on your 64 bit computer. https://www.digitalfaq.com/forum/video-restore/10178-started-avisynth-avspmod.html Most plugins are 32 bit. The 64 bit version of Avisynth has some advantages because it allows you to use more than 4 gb of ram so it’s faster for some complex scripts like QTGMC.
The following users thank Gary34 for this useful post:
oddmykyta (04-22-2024)
04-22-2024, 02:57 PM
already digged for that. the problem is that the system automatically installs the matching (x64) version of AviSynth. If you could provide me some manual method doing that u would have saved me. thx in advance
04-22-2024, 03:59 PM
I’m not sure then.
04-22-2024, 06:38 PM
I downloaded AviSynth_260.exe from https://sourceforge.net/projects/avi...Synth%202.6.0/ and the file size is identical to the installer I used almost 7 years ago for my XP 32-bit machines, so this should be the identical installer I used.
04-22-2024, 06:42 PM
Just as i did. It is identical. But as i mentioned it automatically registers your installation to a matching OS version. I guess i will end up using ur advice about virtual machines, and just install the win7 x32. Thanks though.
04-23-2024, 11:36 AM
Not sure whether it helps, using Vapoursynth with QTGMC, Crop, BalanceBorders and EdgeFixer
image: ttps://ibb.co/4RSF9QP
(did no additional denoising, color corrections, etc. )
The parameters I used for BalanceBorders and EdgeFixer should be similar to those used in Avisynth.
Cu Selur
The following users thank Selur for this useful post:
oddmykyta (04-23-2024)
04-23-2024, 02:07 PM
Hybrid works well in windows 10
Yesterday, 11:17 AM
unfortunately it just adds up more noise. Its works on the standing environment like static shots. by any camera movement the strange noises are created. But thank you for your help.
One more question. Is it possible to remake an earlier provided code by keaton in Hybrid? Asking since chromashift filter is included to Hybrid. If yes i would be happy to know hof exactly. I couldnt find out the right way to go with overlayering and so on.
Code (by keaton) is attached.
Thanks in advance.
Yesterday, 11:33 AM
You would need to write a custom section, since Hybrid has no options for the overlay mixing that is done in the script.
Cu Selur
Yesterday, 11:37 AM
So basically i should get 2 videos that have to be overlayed, apply the needed filter for them in Hybrid, and then do the overlaying using avisynth? Thx
Yesterday, 11:45 AM
No.
You would have to either do this part of the Avisynth script in a custom section in Hybrid (if you use Vapoursynth conver this to Vapoursynth beforehand)
# Shift original clip chroma (both U and V channels) right 14 columns, then keep only the right most
# 26 columns (the 14 with the color issue and the 12 black columns to the right of that), fill the
# remaining columns to the left of that as black
b=ChromaShift(C=14).crop(694,0,0,0).addborders(694,0,0,0)
# Make a copy of the original clip with the right most 26 columns cropped off
c=a.crop(0,0,-26,0)
# Overlay the copy of the original (c) on top of the Chroma Shifted copy (b) with full opacity
Overlay(b,c,0,0,opacity=1.0)
Of feed this (properly adjusted) to Hybrid.
The rest of the script can be done in Hybrid.
=> I doubt you will be able to do this all in Hybrid, since you know to little about Hybrid, Avisynth and Vapoursynth.
Cu Selur
Yesterday, 11:49 AM
thank you. lets see.
im here to learn tho..
Reason: 1
Yesterday, 12:24 PM
Since you want to learn,... you can do the following in Hybrid to achieve:
c=a.crop(0,0,-26,0)
(this basically an alternative to BalancedBorders)
in Vapoursynth: - Start Hybrid
- Load Source
- enable "FilteringVapoursynth->Custom->Insert before DeCross", enable the edit section and enter:
import chromashift
import havsfunc
b = chromashift.ChromaShift(clip=clip, shift_right=14).std.Crop(left=694).std.AddBorders(left=694)
c = clip.std.Crop(right=26)
clip = havsfunc.Overlay(b,c,0,0,opacity=1)
Setting Level, Tweak and Letterbox to mimic the rest of the script should be easy.
Cu Selur
Yesterday, 12:27 PM
c=a.crop(0,0,-26,0)
- Load Source
import chromashift
import havsfunc
Cu Selur
Thank you. Will try this out and tell about results.
Yesterday, 02:33 PM
Didn´t expect that message again.
Since chromashift is built-in filter, im now not sure about next step.
Yesterday, 02:49 PM
Ahh,.. I know what the reason is.
I'm using a newer version with some changes, the 'import' doesn't know where to find the script.
(newer version by default already loads the script folder)
=> I'll package my dev version and send you a link in ~15min.
Cu Selur
Yesterday, 02:50 PM
Thank you man, much appreciated
Yesterday, 03:03 PM
Send you a link via pm.
Have fun, going to bed now.
Cu Selur
oddmykyta (Yesterday)
Thread |
Mitsubishi HS-HD2000U Top of Screen Has Colored Diagonal Lines
invictus005 |
5 |
12-16-2019 12:08 AM |
Panasonic ES10 as passthru adds colored flicker at top of image?
Firewing |
10 |
12-01-2019 12:36 PM |
How to remove horizontal lines caused by damaged tape?
spanak |
14 |
06-04-2018 04:41 AM |
U-matic tape colored square glitches?
HanSoloBerger |
1 |
10-05-2017 09:50 AM |
How can i remove black bar from side of mpg??
Konfusion |
12 |
11-27-2007 05:04 AM |
