Quantcast KDVD: I-Frames While Encoding? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Video Encoding and Conversion
10-26-2007, 08:25 AM
gamma gamma is offline
Hi guys,
A quick question: is a m2v with all I-frames DVD compliant?
I have a very short clip, quality must be as high as possible so I want to drop the B and P frames.
Thanks!
Site Staff / Ad Manager
10-28-2007, 06:25 PM
kwag kwag is offline
Originally Posted by gamma
Hi guys,
Thanks!
I don't think all I frames video at a high bitrate (above 9,800Kbps) is compliant, and won't play on a standard DVD player.
Anyway, make sure you encode at least 30 Mbps to 50 Mbps if using only I-Frames, if you want to have pristine quality.
-kwag
10-29-2007, 05:43 AM
Ok, tnx!
TMPGEnc: Converting 25 frames into 25 frames madmega Video Encoding and Conversion 2 09-13-2008 07:38 PM
Can KDVD be 23 frames per second? The Untouchable Video Encoding and Conversion 5 07-08-2004 10:16 AM
Will CCE report if they skip frames while encoding? rs008f Video Encoding and Conversion 6 03-01-2004 05:32 PM
KVCD: Encoding only some frames of movie? paull2k Video Encoding and Conversion 9 07-16-2003 12:44 AM
KDVD: number of chapters chosen exceed the number of frames?? SodGawd Video Encoding and Conversion 3 04-29-2003 09:44 PM
All times are GMT -5. The time now is 07:14 AM  —  vBulletin © Jelsoft Enterprises Ltd
