Quantcast Recording Video: Direct DVD Editing ? - digitalFAQ.com Forums [Archives]
Go Back    digitalFAQ.com Forums [Archives] > Video Production Forums > Video Capturing / Recording
02-11-2003, 06:44 AM
noize noize is offline
hello,
does anybody knows about a program or plugin that can directly edit from a dvd source?
i have a large archive of raw footage on mini-dv tapes, and i would like to reverse them all on dvd to preserve quality and have them all accessible in a simpler way.
the problem is that i need to edit this footage, and so i need a program (or plugin) that would allow me to do the job without reversing the dvd on hard-disk..
the only way i found so far is using dvd2avi --> vfapi reader --> adobe premiere.. but the vfapi .avi file is difficult to edit (the motion is not smooth, obviously; and the sound track is separated etcetera..)
does it exist a program that can solve my problem?
thank you very much
noize
Site Staff / Ad Manager
02-11-2003, 12:59 PM
kwag kwag is offline
I believe you need a program to edit DV. Not MPEG-2. Have you tried Pinnacle Edition DV
-kwag
02-11-2003, 01:29 PM
Hello Kwag
actually, i can edit my DV footage in Premiere, with no problems at all. the fact is i'd like to get rid of of the dv-tapes and have my footage on dvd (faster accessibility, longer lifetime, reduced storage size, etc.)
then in an editing software, directly access the vobs and treat 'em exactly as a dv source. without having to convert the parts i need to dv-avi (or whatever my editing software likes) and then edit them as i'm used to..
this would be a time consuming procedure and would mean a loss in quality (due to decoding, re-encoding) that i'd like to avoid.
i don't know, maybe they still have to invent such a piece of software
thanks anyway, any idea is welcome
noize
02-11-2003, 02:13 PM
el_mero_zooter el_mero_zooter is offline
Send a message via MSN to el_mero_zooter
have u checked out some of the dv apps like the ones that follow..
http://1newdigitalvideoeditingsoftware.com/video/
http://www.digitalvideoediting.com/2...procoder12.htm
http://www.digitalvideoediting.com/2...zidvcut102.htm
http://www.videoguys.com/DVDauthor.html
02-11-2003, 03:52 PM
wow! thanks for the links, i'll check 'em out!
Video editing in Windows Vista? Dialhot Computers 7 04-13-2007 12:32 AM
Video editing projects to contribute ? Dialhot Off-topic Lounge 2 12-30-2006 04:21 PM
KeepVID - Download videos DIRECT from most video sites kwag Computers 3 10-21-2006 02:37 PM
DVD Burner: DVD+RW Direct On-disc Editing Hydeus Blank Media / Burning Discs 1 10-12-2004 03:30 AM
Recording Video: Best budget-priced video capture card? digitalvideo Video Capturing / Recording 2 04-17-2003 09:31 AM
All times are GMT -5. The time now is 11:28 PM  —  vBulletin © Jelsoft Enterprises Ltd
